Page 3 of 6 FirstFirst 12345 ... LastLast
Results 21 to 30 of 51
Thread: Will a 6 pinion planet gear work in 4L65E
  1. #21
    Default OEM 4-pinion and 5-pinion gearsets
    OEM front/input gearset tooth count:
    sun = 34
    ring = 70
    planet = 18
    (check 34+2*18=70)
    sun:ring velocity ratio (mechanical advantage) = 70/34 = 2.0588
    OEM rear/reaction gearset tooth count:
    sun = 34
    ring = 78
    planet = 22
    (check 34+2*22=78)
    sun:ring velocity ratio (mechanical advantage) = 78/34 = 2.2941
    1st gear:
    front gearset only:
    sun = input
    ring = held
    carrier = output
    In the matrix below:
    0 = held stationary relative to case
    -1 = reverse rotation
    Code:
    Represent this using a 1x3 matrix:
    [ sun       ring    carrier ]
    [ 2.0588     -1        0    ]
    [ 3.0588     0         1    ]   (added 1 to all elements)
    input = 3.0588, output = 1
    So 1st gear ratio is 3.0588.
    2nd gear:
    front carrier drives rear ring and front ring drives rear carrier simulatenously.
    front gearset:
    sun = input
    ring = rear carrier
    carrier = rear ring = output
    rear gearset:
    sun = held
    ring = front carrier = output
    carrier = front ring
    Code:
    Represent this as 2x3 Matrix:
    [ [ sunfront  ringfront  carrierfront ]
      [ sunrear   ringrear   carrierrear ]
    [ [ 2.0588  -1  0 ]
      [ 2.2941  -1  0 ]
    [ [ 3.0588  0        1       ]   (added 1 to row)
      [ 0       -3.2941  -2.2941 ]   (subtracted 2.2941 from row)
    [ [ 4.3921  0        1.4359 ]    (multiplied row by 1.4359 from next row)
      [ 0       1.4359   1      ]    (divided row by -2.2941)
    [ [ 1.3333  0        0.4359 ]    (multiplied row by 0.4359/1.4359)
      [ 0       1.4359   1      ]
    [ [ 2.3333  1        1.4359 ]    (added 1 to row)
      [ 0       1.4359   1      ]
    [ [ 1.6250  0.6964   1      ]    (divided both rows by 1.4359)
      [ 0       1        0.6964 ]
    input = 1.6250, output = 1
    So 2nd gear ratio is 1.6250.
  2. #22
    Default PATC 6-pinion front gearset, OEM rear gearset
    PATC 6-pinion front/input gearset tooth count:
    sun = 38
    ring = 70
    planet = 16
    (check 38+2*16=70)
    sun:ring velocity ratio (mechanical advantage) = 70/38 = 1.8421
    sun = 34
    ring = 78
    planet = 22
    (check 34+2*22=78)
    1st gear:
    front gearset only:
    sun =
    input
    ring = held
    carrier =
    output
    Code:
    [ 1.8421     -1        0    ]
    [ 2.8421     0         1    ]   (added 1 to all elements)
    input = 2.8421, output = 1
    So 1st gear ratio is 2.8421.
    2nd gear:
    front gearset:
    sun =
    input
    ring = rear carrier
    rear gearset:
    sun = held
    Code:
    [ [ 1.8421  -1  0 ]
      [ 2.2941  -1  0 ]
    [ [ 2.8421  0        1       ]   (added 1 to row)
    [ [ 4.0810  0        1.4359 ]    (multiplied row by 1.4359 from next row)
    [ [ 1.2389  0        0.4359 ]    (multiplied row by 0.4359/1.4359)
      [ 0       1.4359   1      ]
    [ [ 2.2389  1        1.4359 ]    (added 1 to row)
      [ 0       1.4359   1      ]
    [ [ 1.5592  0.6964   1      ]    (divided both rows by 1.4359)
      [ 0       1        0.6964 ]
    input = 1.5592, output = 1
    So 2nd gear ratio is 1.5592.
  3. #23
    Senior Member MyM8V8's Avatar
    Aug 2008
    Default PATC 6 Pinion Gear set photos
    Hi Joe,
    Here are pictures of the part discussed.
Name:	patc 6 pinion set1.JPG
ID:	6609   Click image for larger version.
Name:	patc 6 pinion set2.jpg
ID:	6610   Click image for larger version.
Name:	patc 6 pinionset 3.JPG
    2005 HSV Maloo Ute, HKE 457ci Stroker LS2 E40, TFS 245's, 255/263 Hi Lift HUC, FAST LSXr 102, NW Billet 102 TB, FLT Level 7 4L65E, CircleD 4200 stall, Duspeed OTRCAI - Mafless, DF 1 7/8" LT's, 3" DiFilipo Duals, Serial LC-1 WB's
    "An Old Dog learning new tricks"
  4. #24
    Aug 2008
    Default Sonnax uprated input drum kit for 98-05 4L60E/4L65E
    These are photos of the above kit. Sold by PATC as the Raptor Drive kit. It is essentially the later hardened reluctor shaft and drum from the ISS equipped boxes, with a modified stator support shaft, which allows it to be fitted to the earlier non reluctor LS1 type 300mm boxes 98 to 05. The kit also includes an uprated overun piston and the aluminium drum has a hardened steel re-inforcement ring pressed over the inner flange as shown.
    Unfortunately this drum is the weak link of these boxes structurally. We need a 300m version - Mr P ?!!!
    ETA: You can see "special use only" stamped on the stator support shaft.
Name:	patc raptor drive input set.JPG
ID:	6612   Click image for larger version.
Name:	patc raptor drive reinforcement ring.JPG
  5. #25
    Aug 2008
    Default Pics of some other gearbox "Hard" ware:
    As you requested Joe, some of the other nice shiny bits for the build:
    Sonnax performance kit, Superior Industries Billet Servo kits, Alto Carbonite 2-4 band, Rollerised reverse drum, beast sunshell, PATC 300M output shaft, PML +4 qt Ally pan, Poly bush gearbox mount.
    It's OK I sold the wife.
Name:	sonnax performance pack.JPG
ID:	6614   Click image for larger version.
Name:	superior ind servo kits.JPG
ID:	6615   Click image for larger version.
Name:	alto carbonite 2-4 band.JPG
ID:	6616   Click image for larger version.
Name:	beast reaction sunshell.JPG
ID:	6617   Click image for larger version.
Name:	patc 300m 4l65E output shaft.JPG
  6. #26
    Aug 2008
    Default And more:
    More pics.
Name:	rollerised rev input drum.JPG
ID:	6619   Click image for larger version.
Name:	pml +4 QT pan.JPG
ID:	6620   Click image for larger version.
Name:	box poly mount.JPG
ID:	6621   Click image for larger version.
Name:	modified stator support shaft.JPG
  7. #27
    Thanks for the pics... this will be a nice strong box...
  8. #28
    Aug 2008
    Hey Joe,
    Thanks for the Math, not my strong point so=awesome.
    Which leads me to another Q. As 1st will now be higher (2.84 vs 3.05). I presently have 3.46 in the diff. I also have a set of 3.73's in my cupboard.
    Do I put the 3.73's in to compensate (Although I am expecting more HP and Torque from the new motor whcih should drive the higher ratio ok).
    ETA: Ute is 3300lbs.
  9. #29
    Oh, the one thing I forgot to mention about the math is: use these better precision (more digits) values 2.8421 and 1.5592 instead of 2.84 and 1.56... I am not sure exactly, but the better precision will always help the TCM.
  10. #30
    I would try first with the 3.46 gear and note what difference the PATC gearset makes...
    Then when you go with the 3.73 gear you will note the difference the 3.73 gear makes...
    Otherwise, you won't be able to attribute the individual differences.
    My $0.01.
  1. 4L65E (with LS2) in RX7
    By MyM8V8 in forum 4speed RWD/FWD Transmission Tuning (incl T42)
    Last Post: March 12th, 2010, 04:35 AM
  2. What gear am I in??
    By bobbycollier in forum General (Petrol, Gas, Ethanol)
    Last Post: September 9th, 2009, 04:06 AM
  3. scanner buttons work work?
    By pullincrazy88 in forum FlashScan V2
    Last Post: May 16th, 2009, 01:12 PM
  4. Stock 4L65E sluggish 1-2 shift at light throttle - Dashboard attached
    By pacer265 in forum 4speed RWD/FWD Transmission Tuning (incl T42)
    Last Post: July 12th, 2008, 06:25 PM
  5. Modulated 4l65E
    By Forum 12 in forum 4speed RWD/FWD Transmission Tuning (incl T42)
    Last Post: March 30th, 2007, 12:05 PM
