Page 1 of 3 123 LastLast
Results 1 to 10 of 23
Thread: Fuel pressure
    Apr 2006
    Default Fuel pressure
    Is anyone having luck with controlling the fuel rail pressure? I'd like to be able to bring pressure up sooner to help with my bigger nozzles, but this table isn't correct to begin with. At 720RPM idle speed I see 30 MPA when up to operating temp, not even close to the 60MPA shown for the area I'm idling at. Cold start never gets that high either.
Name:	rail pressure.jpg
    Mar 2007
    there are multiplier tables at work between the ECT, IAT , and baro tables. dont know what software version your running but my desktop has been updated to the DSP beta and my fuel pressure column is way different than what you have posted. my lap top is not updated yet but its not here to look at. i'm guessing that the ultiplier tables are takeing affect and why your seeing less than what the base tables are showing
    Apr 2006
    The rail pressure table are not correct. I just loaded a tune into my truck with 30MPA additional across the board, on every rail pressure table. Check rail pressure at idle before and after loading the tune and it is the exact same, 30MPA.........
    Mar 2007
    hmmm interesting
    Sep 2007
    Quote Originally Posted by DuramaxPowered View Post
    what version are you running Down load the latest Dsp release that went out last night the lmm tables are fixed
    Apr 2006
    Quote Originally Posted by fire0021 View Post
    I'll try them, I updated my desktop to the LMM DSP calz, but not my laptop......
    Apr 2006
    It was brought up on another forum by Dustin from Diesel Addiction that there may be a table similar to {B1012} for an LLY that we're missing.......
Name:	lly rail pressure at idle.jpg
    Jan 2006
    The rpm axis is off. Use the LBZ
    0 400 600 800 1000 1200 1400 1600 1800 2000 2200 2400 2600 2800 3000 3200 3400 3600 3800 4000
    Custom Tuning Services
    Apr 2006
    No, it's not the labels. I added 30MPA to the entire table, on every rail pressure table, flashed the tune and the rail pressure didn't change at all.
    Jan 2006
    Didn't mean to be premature. I will be following this as well. I was given that guidance and was passing it along.
    If you are correct, this is a big problem for me.
    Ross, can you squeak this in, buddy, pal, prettty please. ??
  1. Fuel Rail Pressure's relationship to fuel economy.
    By duramaximizer in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: February 28th, 2010, 01:18 PM
  2. vx ss fuel pressure????
    By HINDZY in forum Gen III V8 Specific
    Last Post: October 12th, 2007, 02:27 PM
  3. LOW FUEL PRESSURE logging for low fuel pressure nirtous systems
    By WiseGuyZ06 in forum External A/D inputs
    Last Post: October 11th, 2007, 12:56 PM
  4. Fuel Pressure.
    By 06bowtie_guy in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: April 24th, 2007, 06:37 AM
