Page 3 of 4 FirstFirst 1234 LastLast
Results 21 to 30 of 34
Thread: roadrunner not found
  1. #21
    Oct 2004
    The one in the 'C:\Program Files\EFILive\Drivers\EFILive\Win-2K-XP-Vista' folder.
    Andrew
    EFILive Crew
  2. #22
    Oct 2006
    I have to redo my internet settings on the laptop. Hopefully wont take long.
    The Tremor at AIR
  3. #23
    Oct 2006
    I am not having any luck with the net either. I will send you a pm to set up a time to have a look.
    Thanks again Mick
    The Tremor at AIR
  4. #24
    Jul 2007
    Quote Originally Posted by Tordne View Post
    Getting it to work as Native USB is the preferred option. This requires pointing the driver loading to the same driver as FlashScan (and not the RoadRunner driver surprisingly).
    I've actually just connect mine again to make sure it was all still working. Man I miss using that thing. Being able to read and flash in 10 seconds rocks!
    Which driver is EFI using for FlashScan?
    07 Silverado DMax Classic
    02 Z06 LS3 416, 805rwhp, TFS245, Wiseco, Callies Crank/Rods, Iskendarian Lifters, Crower Rockers, FAST102/90, ATI Damper, 1-7/8 Kook's LT, QkTime Shield,Tolle-Fab 8pt
    Old Engine: 1/4mile = 9.6/146 New Engine:?
    EFI Live Tune/Scan v7.5.27, EFI Live Scan and Tune v8.2.23, build 276, BootBlock 2.07.06, FirmWare 2.07.52, 512K RoadRunner (12.14.R), Innovate Serial LC2x2
    COS5/12212156 For 2002 Z06 Manual Vette
  5. #25
    Oct 2004
    Both the FlashScan and RoadRunner devices use FTDI drivers. The reason (in my view) that the RoadRunner is sometimes difficult to get working is that it presents as a generic FTDI chip and drvers are often automatically loaded by Windows Update. FlashScan on the other hand has altered vendor and device strings and will therefore need to drivers to be loaded manually.
    Andrew
    EFILive Crew
  6. #26
    Jul 2007
    Interesting. RR presents as a generic FTDI Chip, FT232R I believe, but with no name change, VID representing FTDI. I have mentioned to Craig M in the past, should consider renaming his devices, so they can directly open it via "string" and FTD2XX.DLL, native mode obviously.
    I wonder if he plugged one device in before the other if that might help. Not sure how EFI is port checking, first FTDI device found first checked or what, but with no device id nor name, got work a little harder.
    Gotta go get ready for vacation. Good luck to the op.
  7. #27
    Oct 2004
    I would probably be inclined to connect the FlashScan first and load the drivers by browsing to the folder path above. Then connect RoadRunner (either with FlashScan connected or not - shouldn't matter). It might be that the RoadRunner still goes and gets a different driver. If so you have to do the "Update Driver" trick.
    Hopefully I can get it sorted for him if we can get remote access organised
    Andrew
    EFILive Crew
  8. #28
    Oct 2006
    Well dont I feel like an idiot. After having a decent look I noticed that the preferred com port was already assigned. Change that to a different port & all is well.
    Thanks again Tordne for the offer of assistance & you other guys for posting as well. It always seems to be the small errors that give the largest headaches.
    On the bright side my laptop is much quicker than its ever been. Now to do the same to the ute.
    The Tremor at AIR
  9. #29
    Oct 2004
    So your next challenge is to get it working in Native USB Mode LOL.
    Andrew
    EFILive Crew
  10. #30
    Oct 2006
    HA HA HA HA. NO!
    I will try that next time I have a week to spare LOL.
    The Tremor at AIR
  1. WB not found
    By driver456 in forum FlashScan V2
    Last Post: May 30th, 2010, 03:59 PM
  2. Options.ini not found
    By VHR in forum FlashScan V2 BB Logging
    Last Post: July 13th, 2008, 11:54 AM
  3. no controller found
    By mr.prick in forum FlashScan V2 BB Logging
    Last Post: April 8th, 2008, 12:02 PM
