Results 1 to 10 of 16
Thread: Need help with a load vs. rpm vs. KR MAP!
    Default Need help with a load vs. rpm vs. KR MAP!
    I am just trying my first custom MAP to log KR on the dyno. I set up the columns up with KPA values and gthe rows by RPM. The data tab was noted as retard due to knock.
    After I made the map I loaded up a presaved log file that had indicated knock retard. No values show up. Is there an issue with pulling up old log files with new maps? Is there another parameter I didn't activate?
    If the log file recorded data can't that data be configured anyway you want with there custom maps.
    Sorry if it is a basic question..
    Howard
    www.redline-motorsports.net
    1-954-703-5560
    2006 ZO6 895/866 with APS TT
    2011 HTR-850R Camaro
    No issue, you can set up new maps after the log is recorded.
    Make sure you used exactly the same PIDs that are in the log file as your three MAP PIDs.
    i.e. if you logged {SAE.MAP} in the log and used {GM.MAP} as the column labels in the MAP then it would not work.
    Also, check that you don't have "hide empty cells" turned on and set to a value that hides all your data.
    Paul,
    I do not see where the selectable items have extentions such as.KR, .MAP, etc.....
    I selected the only rpm selection for the column and the only kpa selection for the rows. Just as it appears in the VE table. I then used the knock retard parameter for the data or name indicated at the top of the map. I did make sure that cells are not hidden.
    definately doing something stupid!
    1-954-703-5560
    There is a check box under the PID selection drop down list box (in the MAP property editor) called "Name". Check that box and the PID names will show up in the list - that way you can know for sure which PID you are selecting.
    Aug 2004
    Howard, You can call me, i could have walked you right thru it....
    Thanks Jesse!
    I think I got it working but have another stupid question; I have the map set up as follows;
    Column is MAP in Kpa
    Rows are RPM
    Name of Map is KR (average) ?
    After making the above map I loaded a known log file which had recorded some KR. I played the log and the new map registered. What the hell am I looking at? I would have thought it would have displayed the "actual" KR in its given rpm/load cell but there numbers don't correspond to the KR on the dashboard. Is it in deed the average? If so how do I get it to read the acutal KR?
    1-954-703-5560
    There are 4 options that you can display:
    Min, Max, Avg, and cell count.
    Look int he MAP toolbar you'll see an icon for each one.
    - Olive colored down arrow for Min.
    - Olive colored up arrow for Max.
    - Black x (with a bar over it) for average.
    - Black n for cell count.
    View KR as Max - that will show you the max KR for each cell.
    Jan 2004
    Quote Originally Posted by Redline Motorsports
    The only way to look at the actual value for a MAP is to use the dashboard. There is no "current/actual" option for the MAPS to view the real time value. MIN/MAX/AVG/Count only.
    How about that for an option Paul?? MIN/MAX/AVG/ACT/Count...
    Quote Originally Posted by black02ss
    Another present to put in Santa's sack
    Jan 2004
    I wish it was that easy when I was a kid... :lol:
    Once again, top notch customer service. :thumbsup:
    PS: I am in a asking mood.... How about some new smilies..
  1. Can you load a cal into a COS without an ECM?
    By onfire in forum Custom Operating Systems
    Last Post: July 13th, 2009, 02:09 AM
  2. AFR relation to RPM and load?
    By zapp168 in forum General (Petrol, Gas, Ethanol)
    Last Post: April 5th, 2009, 07:54 AM
  3. C.O.S. will not load.
    By Webbs in forum Custom Operating Systems
    Last Post: October 2nd, 2008, 05:59 AM
  4. Need Help - ECM load failer
    By kodydog in forum Duramax LLY
    Last Post: November 29th, 2007, 04:52 PM
  5. Can't uninstall v7.1.9, and can't load v7.2.2
    By VT2_SS in forum Tutorials
    Last Post: May 12th, 2005, 11:31 AM
