I'm prepping to do the AutoVE thing and get the wideband in, so I set up my tune as SD, failed the MAF. I am only getting like 9-12.5 degrees of timing at WOT and if you go to the high octane spark table its supposed to be like 23. If you open up the spark IAT table with the log file open it's highlighting the 50-55 degrees Celsius whereas the log is showing actual IATs of 12-15 degrees Celcius. Even then though the IATtable pulls like 5 so I dont know where else its pulling from.
