Results 1 to 2 of 2
Thread: RTAC not working right
    Jan 2006
    Default RTAC not working right
    I tuned a camaro the other night and everything worked perfect. I went to tune another a few days later and turned on RTACs on the fuel table during autove and it would follow the scan tool. I couldnt find anything differnt. It would follow the rpms correctly but it wouldnt move out of the first column of the ve table. What happen?
    Nov 2006
    The MAP units probably didn't match between the scan.ex and tune.exe
    The recorded PID's units need to match the table's units.
    LC-1 WBO2
  1. A way to cheat and fix your strims/ltrims using Rtac Very quickly.
    By wait4me in forum RoadRunner Real-Time PCM Emulator
    Last Post: April 25th, 2016, 08:21 AM
  2. DSP 5 not working
    By minytrker in forum Duramax LB7
    Last Post: March 9th, 2010, 10:22 AM
  3. C.A.S.E not working
    By uaesands in forum E37, E38 & E67 PFI ECM's
    Last Post: September 25th, 2009, 02:38 AM
  4. RTAC's Map not working
    By driver456 in forum RoadRunner Real-Time PCM Emulator
    Last Post: November 1st, 2008, 01:34 PM
  5. rtac question
    By ty_ty13 in forum RoadRunner Real-Time PCM Emulator
    Last Post: July 30th, 2007, 10:05 AM
