Results 1 to 1 of 1
Thread: Too much boost and Turbo Vane "TARGET" Position-LMM
    Jan 2006
    Default Too much boost and Turbo Vane "TARGET" Position-LMM
    B2214, B2215
    On appearance, these table appear to be vane "minimum" tables.
    I have to do some more experimenting, but has anyone had a similar issue with overboost? This LMM sure like to make boost, albeit uncommanded. I am either getting extra boost from a table I can't point to, or my vanes are being commanded to minimums by these target tables, or other tables.
    I know in earlier ECM's, "target" position did not constrain vane position.
    EDIT: It doesn't appear to be vane tables at all now. DES and ACT boost are about the same. Could it be, yet another set of tables with vertical axis scaling error?
    Custom Tuning Services
  1. Turbo Vane Target Position Question
    By dieselz28 in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: March 21st, 2010, 12:38 AM
  2. LMM-Turbo Vane Target Position
    Last Post: January 23rd, 2010, 06:31 AM
  3. P2563 code "Turbocharger Boost Control Position Sensor Performance"
    By Truckin Stuff in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: December 3rd, 2009, 01:11 PM
  4. EFILive "Classic"/"Legacy"/"Historic"?
    By emarkay in forum FlashScan V2
    Last Post: November 2nd, 2008, 02:48 AM
  5. Min. turbo vane position?
    By IdahoRob in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: April 9th, 2007, 10:56 PM
