Hello Everyone,
Im running COS3 in Speed density. My setup is a 2000 camaro, 427 with two TC66 turbos. I have the car properly in SD mode.
When I hit the gas the timing drops all the way to 10 degrees and never really comes back up even if I am commanding 11 or 12 degrees.
I am going to log all of the timing pids I can find, but I do not understand why it wont run higher or even lower timing.
I tried setting the timing in the 1.20 Dyclair in the tune tool to 9 and even 8 degrees of timing, but it always sits at 10??
Any help would be appreciated.
Thanks,
Glenn
