What is the difference between CALC and Calculated PID files?
Y2K C5, M6, LS6 intake, Kooks LT headers, High flow cats, 216/224 113 LSA, 5.3 Stage II heads. STS twins. COS
Not sure I understand your question...
Did you make a new calculated pid and use CALC as the System instead of Calculated? If so there is no difference that I know of except it will place it in a new group when displayed by the PIDS( F8 )screen. If this is the case, go back into your calc_pids.txt file and change the CALC to Calculated under System.
Yes, that's how the CALC pid group came about. Thanks.Originally Posted by black02ss
