I know this has been covered in some old posts but it seems it was never answered completely---
When installing LT headers and the 02 bung locations are futher back--How can you correct the PT closed loop fueling to compensate ?
My experience shows that typically the closed loop fuel will get richer with LT headers--I've seen about a wideband 14.0 average --- Can you fool the ECM by changing table B3601 (Stoich) from 14.68 to like 15.0 ?
OR should you change the swtiching points B4105 to correct the fuel back to 14.68 ? and should you add or subtract millivolts from the table ? By my way of thinking you should subtract from the switching points---but i tried that and have seen liitle change with the wideband
Or should you do both ?
