Results 1 to 9 of 9
Thread: 09 zr1 tune?
    Oct 2007
    Default 09 zr1 tune?
    does anyone have a stock one? or know where i can find a stock one? thanks..
    01 Z06, 4L60E CONVERSION, L92/L76 TOP END, 72# LS3 INJECTORS (THANKS FIC), DRY NITROUS, COS5
    Lifetime Member Chalky's Avatar
    Sep 2003
    Here you go!
    2015 Z06 A8
    Lifetime Member Boost's Avatar
    Dec 2006
    Anyone see any room for gains just by reviewing the tune without a log? Also I'd like to learn how they "detuned" the V from 638 hp to 556. It's the same LS9, what would happen if I flash a ZR1 tune into a CTS? Instant 100 hp gain?
    8.7 @ 84 (1/8 mile) bolt-ons
    Doesn't the V run with lower boost...?
    Can someone post a tune file from a V.
    Oct 2007
    thanks people...got it... the reason why i needed one is cus ima get some modded ls9 zr1 injectors that flow 85#'s from fic injectors. i need the injector specs from the tune so i can put then in my ls1 pcm which is different....anyone have any ideas on what to copy and paste on my ls1 pcm tune?
    the tables between the 2 pcm's are way different
    thanks
    The V uses a different engine, the LSA vs the LS9...smaller blower, different valves IIRC, and maybe different heads too.
    Dec 2006
    Wow, I really didn't know that. Thanks. Still want a V bad!!
    Jul 2003
    Does anyone have a 10' zr1 tune 12635947?
    Senior Member Sid447's Avatar
    Jul 2005
    .........There's one of each (MY2009)
    In the holdencrazy tune file library:
    ....or am I missing something.
  1. Replies: 5
    Last Post: August 5th, 2008, 02:35 PM
  2. Tune VE and MAF tables or leave VE stock and tune MAF only
    By BlackGMC in forum Gen III V8 Specific
    Last Post: August 4th, 2008, 08:05 PM
  3. What else can I tune without scanning or black boxen it? Tune history inside.
    By Round Rock TJ in forum General (Petrol, Gas, Ethanol)
    Last Post: May 3rd, 2007, 02:27 AM
  4. Convince me to change to a 2bar tune...709rwhp through an EFI maf tune.
    By onfire in forum Forced Induction and Nitrous Oxide (N20)
    Last Post: June 16th, 2006, 12:04 PM
