Results 1 to 8 of 8
Thread: Efi live with autotap cable
    Dec 2008
    Default Efi live with autotap cable
    I have the latest build and i tried hooking up to a 2009 Chevrolet truck 2500 and on the control panel says no controller found. Will the autotap cable not work on this type of PCM with efi live??? I have had no other problems with other vehicles older than this
    You will need a software license key, I pm'd Tech Support.
    Which AutoTap cable do you have...?
    Which build of V7.5 software are you using (build 99...?)...?
    Dec 2008
    I do I have a license for it I have 7.5 build 88 I hvae used it already on several vehicles already
    Oh, I don't think the AT cable will work with CAN... I'm not sure, I'll find out more.
    Oct 2004
    I'm almost certain the AutoTap will not do CAN vehicles. You will need to get a FlashScan V2 based product to cater for newer vehicles.
    Andrew
    EFILive Crew
    Dec 2008
    Well i ran it through the Autotap program and i was able to get live data and read dtcs. Just cant get it to work with efi live first time ive had this happen i was able to connect to an 08 alright awhile back. Only thing under the hood on the federal emissions sticker it says 2009 year incomplete never have seen that. And i do have the newer red case AT cable is what im using.
    I notified Tech Support some more.
    The red AutoTap ATUSB cable is capable of connecting to CAN vehicle when using the AutoTap software. However, EFILive software does not support CAN vehicles when using the ATUSB cable. The EFILive software only supports VPW vehicles when using the ATUSB cable.
  1. Can I do anything with this AutoTap cable?
    By spoolin7 in forum General (Petrol, Gas, Ethanol)
    Last Post: April 20th, 2010, 04:03 PM
  2. Autotap
    By Grey Silver in forum Gen III V8 Specific
    Last Post: November 24th, 2007, 12:40 PM
  3. Question concerning Autotap/EFI live V5??
    By NVTHIS in forum General (Petrol, Gas, Ethanol)
    Last Post: April 20th, 2007, 06:30 AM
  4. Replies: 10
    Last Post: October 3rd, 2006, 01:52 PM
