Does the ALDU1+CABL1 USB cable work with EFILive V4 and if it does is there anything special that has to be done to get it to work properly. I want to use this on a 1989 Corvette.
Thanks in Advance,
Thanks in Advance,
Yes it does work.
You have to disable the Max232 Echo option in the EFILive V4 Properties window.
