Page 2 of 2 FirstFirst 12
Results 11 to 17 of 17
Thread: Exressions question?
  1. #11
    Nov 2006
    The bracket themselves don't not make the difference in this PID in particular,
    the whole equation is wrong.
    Also notice how the wrong_load pid needed to be spelled
    under description in the calc_pid.txt to be proper in the description row in the PIDs tab.
    That is another issue tho.
    P.S.
    The PIDs here calc_pids(delta_load).txt show the current frame#,
    and the difference in TPS% from the previous frame to the next.
    Example:
    frame #1 TPS% is 10%, frame #2 TPS% is 50%
    delta_load will be 40%
    Values will be negative with TPS% decreasing.
    I use this both for filtering, enjoy.
    LC-1 WBO2
  2. #12
    Ok, problem #1: you need to add 2 blank lines at the end of your calc_pid.txt file.
    I'm still looking...
  3. #13
    Nov 2006
    Thanks Joe.
    Adding more space at the bottom fixed the spelling issue.
    I didn't know that was needed.
    On a side note,
    I have been trying to make a time() PID but it always starts off with a highly positive number.
    I want it to start from 0.
    LC-1 WBO2
  4. #14
    Try "time(frame()) - time(0)" or "time() - time(0)".
    i.e. subtract the timestamp of frame 0 from the timestamp of the current frame...
    this will be in milliseconds, so divide by 1000 to get seconds.
  5. #15
    Quote Originally Posted by mr.prick View Post
    Thanks Joe.
    Lol, I think it may be a bug, and the newlines hide it...
  6. #16
    Nov 2006
    Thanks again Joe
    " time() - time(0)"
    This worked,
    brackets and all.
    LC-1 WBO2
  7. #17
    lol.
  1. Desired Airflow Question, not your normal question
    By Dale in forum General (Petrol, Gas, Ethanol)
    Last Post: October 1st, 2010, 11:10 AM
  2. Locked out timing question for boost setup question??
    Last Post: September 13th, 2005, 03:22 PM
