LC-1 WBO2
The serial cable from my FJO has an end the same as the Flashscan cable. Does that mean I need a "gender bender" adapter?
2002 Chevy truck, SCSB 2WD, Stroked LS3 w/Big Mutha Thumper cam
2002SS Camaro LS7/427 with stock suspension setup
2012 Chevy truck, SCSB 2WD, Magnaflow exhaust + K&N
Yes, probably... does your user manual show a pinout for the serial cable...?
Here is the V2 serial cable diagram,
it's for the LC-1 but you can use it to match the FJO.
1 = Tx Data
2 = Rx Data
5 = Ground
FlashScan to LC-1 and LM-1 Serial Cable Diagrams
LC-1 WBO2
OK. Got the serial connection made today. I'm not sure if the BEN map is correct and I have the correct Pid's working. On the BEN map I was getting numbers like 1.70 but it would follow MAP and RPM.
Also did a little more work on trying to make the AFR read correctly on the dashboard thru the analog. The calc.pid seems to have no effect on it. I can substract 10 from the expression and the AFR readout stays the same. Wonder what has gone wrong there. The analog AFR has worked good for several years until a couple weeks ago when I had to replace a failed sensor.
This is my calc_pid
Try this just for the hellofit
"({EXT.AD1}*2)+10"
For serial you need to change the V2's internal settings and,
use the serial WBO2 PIDs.
For the FJO it has GEN2 & GEN3, is yours a GEN1?
LC-1 WBO2
I tried it both ways already...with and without the brackets...there was no difference.
Searched but could not find where in the V2 for the external signal. Is it supposed to be under setup?
I believe my FJO is the GEN2.
I'll have to get it off my laptop to post the PID's I'm using and the MAP.
