Results 1 to 5 of 5
Thread: Knock Sensor
    Dec 2008
    Default Knock Sensor
    I understand that I can't use LS3 Gen IV knock sensors with my 01 PCM loaded with Custom O/S 5 . Is that correct and I must use my old LS1 knock sensors or is their a work around?
    thanks ed
    Dec 2008
    Anyone?
    Nov 2006
    5.7ute was working on an LS3 transplant,
    I don't know if he ever figured out the settings for the Knock Sensors
    with the LS1 PCM/OS though.
    LC-1 WBO2
    Oct 2006
    I couldnt get it to work properly so I went back to the ls1 sensors, mounted in the side of the block. From a lot of searching I did it appears that the hardware isnt in the pcm to support a flat response type sensor. Whether this is true or not I dont know for sure but I couldnt get it to work consistently enough to be happy.
    The Tremor at AIR
    Dec 2008
    thanks,
    PS does anyone want a good deal on Gen IV knock sensor? I have 3 of them new, picked up a spare cause I got them cheap.
    Ed
  1. Knock Sensor Tuning
    By TBMSport in forum Gen III V8 Specific
    Last Post: November 24th, 2009, 08:34 PM
  2. New pcv - knock sensor calibration?
    By voda1 in forum Gen III V8 Specific
    Last Post: June 1st, 2007, 08:42 AM
  3. Turning off Knock sensor?
    By SinCity-Z in forum General (Petrol, Gas, Ethanol)
    Last Post: February 13th, 2007, 01:52 PM
  4. LS1 to LS2 knock sensor question
    By Redline Motorsports in forum General (Petrol, Gas, Ethanol)
    Last Post: April 26th, 2006, 01:09 AM
  5. LS1 knock sensor with a LS2 block
    By Camaro SS in forum General (Petrol, Gas, Ethanol)
    Last Post: September 13th, 2005, 02:27 AM
