Page 4 of 5 FirstFirst ... 2345 LastLast
Results 31 to 40 of 44
Thread: E38 VATS will not disable
  1. #31
    Jul 2007
    I am kind of wondering cause the PCM is not seeing a "crank request" that it isn't energizing the coils or the injectors...
  2. #32
    Dec 2007
    You could set the EFILive scantool up to look at the injectors and coils and see what they are doing.
  3. #33
    Jul 2007
    I did and they don't change at all while cranking..
  4. #34
    Dec 2007
    Quote Originally Posted by tk-mpl View Post
    When I have scanned without VATS disabled coils and injectors dont change status.
    With VATS disable working they both show activity.
    Have you got full time 12V on pin 20 of body connector and 12V on both pin 19 and 47 with ignition in the run and start positions?
  5. #35
    Nov 2008
    Seems like this is an issue with the 07' 5.3 Silverado's. On my "M" code engine the ECM starter enable wire powers the starter relay trigger, it does not ground it as you would expect; so I ran it through an 80 ohm resistor to ground.
    With this wire left open I would get spark but no injector pulse.
  6. #36
    Jul 2007
    Quote Originally Posted by gmh308 View Post
    not sure what you mean about "body connector". All I got was engine and trans componets..
    Trevor
  7. #37
    Jul 2007
    Just verified 12V on 19,20,47 on C1 of PCM with key on and while in crank position..
    Trevor
  8. #38
    Dec 2007
    Quote Originally Posted by VEGASROBBI View Post
    Which ECM pin does that connect to? Have looked at same for pin 57 of C1/J1 sometimes called "start control relay" and it appears to make no difference but it would depend on OS.
  9. #39
    Dec 2007
    Trevor
    Ok cool. Not uncommon to see 47 missing.
  10. #40
    Oct 2004
    tk-mpl,
    Just to cover off the simple stuff. You have applied the VATS Patch in the calibration and done the necessary full-flash, correct?
    Andrew
    EFILive Crew
  1. E38 / E67 VATS disable guide
    By GMPX in forum E37, E38 & E67 PFI ECM's
    Last Post: March 22nd, 2023, 01:35 PM
  2. cant completely disable VATS in 01 holden SS?
    By Dopey in forum Gen III V8 Specific
    Last Post: September 29th, 2011, 06:58 PM
  3. E38 cant disable VATS
    By minytrker in forum E37, E38 & E67 PFI ECM's
    Last Post: October 30th, 2009, 04:43 PM
  4. How do I disable VATS.
    By PRAY in forum Gen III V8 Specific
    Last Post: February 18th, 2009, 12:45 PM
  5. LBZ/LMM VATs
    By Biodiesel66 in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: July 22nd, 2007, 09:56 PM
