Results 1 to 2 of 2
Thread: LMM DSP switch
    Jan 2008
    Default LMM DSP switch
    Hey guys, I just got the new EFI live and have a couple questions.
    How does one actually install the switch so that it works? I.E. does it need to be connected to the ecu some how?
    Also, the software needed for the DSP switch do I just download that and let it update on my computer or do I need to delete EFI live? How do I know that it actually works?
    Thanks in advance it is much appreciated!
    Apr 2009
    Take a look att this PDF for what release needed. The wiring diagram is in there also. There will be some new PIDs for you to test what position the switch is in.
    Anybody know when the calz for LBZ will be released?
    EDIT - I found it. Must have been blind erlier. /EDIT
  1. Going from DSP2 switch to DSP5 switch
    By Dmax15 in forum Duramax LB7
    Last Post: February 23rd, 2010, 02:25 PM
  2. V1 to v2 switch
    By MIKE P in forum Duramax LLY
    Last Post: January 13th, 2010, 04:54 PM
  3. N20 Switch wiring with OS5
    By BowlingSS in forum Custom Operating Systems
    Last Post: August 13th, 2009, 11:50 PM
  4. where to get a 5 position switch
    By 69camaro5speed in forum Duramax LLY
    Last Post: April 6th, 2008, 11:17 AM
  5. Can I switch my Flashscan-1 from my old C5 VIN to my new C6 LS3?
    By PewterC5 in forum General (Petrol, Gas, Ethanol)
    Last Post: November 14th, 2007, 02:29 PM
