Results 1 to 10 of 10
Thread: did i do this correctly?
    Nov 2008
    Question did i do this correctly?
    I have an FJO WB and have it's 5v output linked to my ext1 in. To calibrate the FJO, I disconnected the FJO from the EFI unit and, with the engine off, I checked the voltage output of the FJO with a DVM (4.56v) steady. I then plugged into the EFI unit and checked the EXT.AD1 voltage (4.38v) average. There was a noticable delta between the two voltages (0.18v). I then added the "dropped" voltage to the "calibrated FJO" PID I made. Below are the details and the attached logs are from me cruising at 65mpg on the way to the track, and the other from a WOT 1st to 3rd run down the track.
    So, did I calibrate correctly?
    Should I trust my calibrated CAFR PID over the default FJO PID?
    DVM 4.56V
    EFI 4.38V
    Delta 0.18V
    Default FJO Calculation afr=v*2.5+8.75
    My Adjustment Calculation afr=(v+0.18v)*2.5+8.75
    Mar 2007
    Interesting thoughts there. I'd like to hear an answer from GMPX on this one. Contact Tech Support or maybe PM joecar.
    Nov 2006
    There is a sticky on calc.pid offsets.
    If your DMM shows a different voltage than the V2 then it needs to be calibrated.
    V2 A/D Calibration - FAQ
    You might want to ask TAQuickness for a serial cable.
    LC-1 WBO2
    Nov 2008
    I'm not disputing you're advice but I do worry when I see the following text.
    "FlashScan is pre-calibrated at the factory and the end user should never
    need to perform the calibratration procedure."
    You may notice I've got an Fuel Pressure input via the EGR. How will this affect it's reading? For that matter, I'm assuming by changing the factory calibration, ANY input may be affected. Correct?
    I was considering the need to perform a similar calibration adjustment to my FP sensor input as well, but maybe I need to keep all of the stock CALCs and adjust the factory calibration settings as your attachment indicates.
    Recommendations for a controlled input voltage? Maybe a couple of batteries?
    Nov 2006
    I had to calibrate mine,
    and if your V2 reads differently from your DMM then it should be done.
    The fact that we have the option to calibrate the AD's is proof
    that it could/should be necessary.
    I use 1 AA battery for the initial voltage and 3 for the calibrate voltage.
    You can get a battery holder at Radioshack.
    I personally suggest the serial connection for WBO2.
    LC-1 WBO2
    Nov 2008
    Ok, I must be dense. I've read the instructions over about two dozen times and repeated the process the same. No matter what I do, I cant get the calibration to change. I (Start) with one AA battery 1.612v (Initialize). Then use two AA 3.25v. (Calibrate)... (Stop)
    I end up with the A/D count 0, Cactor 999.9 and offset 1162.
    When I check the realtime data for my A1 in. I leave the two AA's connected for verification and it will always reads 3.15v NOT 3.25v. I,ve even fudged my numbers a few times to try and force a change, but it never does...
    What am I doing wrong!? :( I know the A/D count should be > 0? What's up?
    Nov 2006
    Are you using the V2 control panel through the scan.exe or EFILive Explorer?
    The scan tool does not work like it used to so use EFILive Explorer or you can
    go through the V2 itself.
    LC-1 WBO2
    Nov 2008
    I'm using the EFILive_Scan.exe FlashScan V2 Control panel. I'll try the explorer.
    Update!!! Perfect. The explorer tool works fine. Thanks.
    It's good to know i'm not a complete goob! I wasn't doing it wrong, just using an old outedated nonworking feature of the scan.exe software. Who'd thunk it! I've liked EFI so far (not had it long), but I think they have a few Microsoft flunkies working on their code!
    Nov 2006
    You need to be connected to the car when you do.
    This is important.
    LC-1 WBO2
    Lifetime Member 67SS509's Avatar
    Dec 2005
    Quote Originally Posted by hhorton View Post
    DVM 4.56V
    EFI 4.38V
    Delta 0.18V
    Noticed on your calc.pid you are using 2.5+8.75, I have a FJO also and have been using 2.0+8.75. Should I be using the same as yours? Probably should check my calibration also.
    2002 Chevy truck, SCSB 2WD, Stroked LS3 w/Big Mutha Thumper cam
    2002SS Camaro LS7/427 with stock suspension setup
    2012 Chevy truck, SCSB 2WD, Magnaflow exhaust + K&N
  1. Analog voltage not recording correctly
    By SweetS10V8 in forum General
    Last Post: December 29th, 2009, 04:07 PM
  2. Replies: 11
    Last Post: July 10th, 2008, 11:44 AM
  3. Anyone have A0014 table working correctly with F.I.???
    Last Post: October 22nd, 2007, 05:02 AM
  4. Conversion Calculator not working correctly
    By AustinL911A in forum General (Petrol, Gas, Ethanol)
    Last Post: February 1st, 2007, 02:42 AM
  5. EFI not reading AFR correctly
    By billyjo in forum General (Petrol, Gas, Ethanol)
    Last Post: December 11th, 2006, 10:55 AM
