Is lean cruise available on u.s. vehicles yet? I own a 2000 gmc with a 2001 o.s was hoping to be able to use the lean cruise. Has of now it does not work, But i read something in here saying there was goin to be a fix soon.
2001 camaro z28 ss vert with factory slp upgrades, Hooker long tubes, 3"y-pipe to a 4" muffler, ,airlid,s.s.r.a. ,t.c.bypass,descreened m.a.f. 232/234 .595,.598 +2 comp cam with ported and polished stock heads with .650 lift dual springs and a bowl grind. tuned with EFI Live. All combined to achieve 29 m.p.g. and 399 r.w.h.p. with 384 lbs of torque. sold...
Now own a 2015 1LE camaro
No and never will be, use a COS and set it up to enable pseudo lean cruise.
I thought the same thing too, but I was corrected in another post a while back!!!!
Link I was corrected in
Hope this helps!!!
Mike
Current toys are as follows:
1961 Chevrolet Corvair Monza, 145 H6/powerglide. 85 HP of raw fury.... slow and stock and staying that way!
1969 GMC 2500, 4-53T Detroit diesel/Fuller 10 speed on late model 1500 HD frame
1970 GMC 9500, 6-71 Detroit/Fuller 13 speed, not sure why I bought it, but it sure is noisy!!!
1975 Ford F100 shortbed. Currently undergoing Crown Vic subframe swap and EFI 4.6!!!
1975 Chevrolet Vega, 5.3/200-4R may finish someday, maybe...
Interesting to know...personally Ive never tested any LS1 based stuff as I dont have access to one. All the LS1 testing Ive done has been in fooling my P10 to think its an LS1 in EFILive for scanning purposes.
I have lean cruise available to me and I don't bother using it. If you use OS3 or OS5 just use B3647 to command what ever AFR you want.
i have build 88 and lean cruise is not still working?? any suggestions and yes it is turned on.
post up the tune and i'll have a look at it for you
330 rwkw EFILIVE OS 01290005 SD Cam / Head Tuned 6 speed VY SS Commodore
10/71 Blown 572 Big Block Chev HQ 2 Door Monaro
GM Performance Centre
Busselton WA
AUSTRALIA
Phone: 0447 003050
give this a try
Busselton WA
AUSTRALIA
Phone: 0447 003050
