Results 1 to 10 of 11
Thread: SRS System
    Sep 2005
    Default SRS System
    Was wondering if anybody has been able to read DTC's from the SRS / ABS system, i think the module is $F7 and $F9 this is for a VT V6 commodore. I have seen in the service manual lots of DTC's up to 130 relating to ABS / SRS faults, also would clearing SRS faults be simply a matter of going into the vehicle data stream editor and under ECM/PCM $0A change the value from $F5 to $F7.
    Cheers
    If you used the correct module ID for the SRS and/or ABS modules then, yes you should be able to send the clear DTCs command the same as you would for the ECM.
    I don't have any SRS/ABS module info to read/decode their DTCs though.
    Sep 2005
    Thanks for your reply, yea tried using F7 and no go
    SRS module IDs should be in the range $A0..$A7
    ABS module IDs should be in the range $90..$97
    Scan the chatter and see which module ID's show up.
    I'm not sure if you can communicate with modules using those ID's, I've never tried it.
    Sep 2005
    Thanks Blacky, ill give it a go, i was just going by what i seen in the efilive doc under the modules section which says F7 is SRS and F9 is ABS...
    Ill let you know
    PS. when you say scan the chatter, what exactly should i be looking for (never used the chatter)
    It may be you need to use $Fx to send specific commands to modules - I don't know.
    The chatter is the BCM or ECM sending a "request" (even ID's) and getting a "response" (odd ID's) from the various modules.
    i.e. chatter may look like:
    $A0,$57,$01,$02,$XX (BCM or ECM requesting info from module $A0)
    $A1,$59,$AA,$BB,$CC,$DD,$XX (Reply from module $A0)
    $90,$57,$01,$02,$XX (BCM or ECM requesting info from module $90)
    $91,$59,$AA,$BB,$CC,$DD,$XX (Reply from module $90)
    Sep 2005
    I have tried
    F2, 56, 0A (this resets the instrument cluster)
    just a question to reset the DTC's from the PCM the string is
    F5, 57, 0A
    Can you tell me what the second (56, 57) byte does
    Cheers
    The second byte is the number of data bytes to follow, less $55.
    So $55 means no data bytes to follow, just the checksum byte,
    $56 means one data byte plus the checksum
    $57 means two data bytes plus the checksum
    etc
    Sep 2005
    Just an update
    sending $F1,$57,$0A,$00,$AE seems to reset the BCM
    sending $F2,$57,$0A,$00,$AD resets the instrument cluster
    sending $F9,$57,$0A,$00,$A6 resets the ABS
    but
    sending $F7,$57,$0A,$00,$A8 does not reset the SRS
    this could be because there is still a fault with one of the modules attached to the SDM (just a theory anyway)
    Try leaving off the second data byte $00 and just send: $F7,$56,$0A,$XX (where $XX is the checksum).
  1. 09 lmm operating system
    By 07.5duramax in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: December 11th, 2009, 12:59 PM
  2. 02 operating system?
    By THEFERMANATOR in forum Allison 5 & 6 Speed
    Last Post: October 25th, 2009, 12:58 PM
  3. Going from 00 to 02 operating system
    By lastcall190 in forum Gen III V8 Specific
    Last Post: November 12th, 2007, 04:50 PM
  4. operating system
    By ls1transam346 in forum Gen III V8 Specific
    Last Post: February 22nd, 2007, 11:49 AM
  5. Custom OS system for the VU Ute
    By Scoota in forum General (Petrol, Gas, Ethanol)
    Last Post: May 26th, 2005, 11:39 PM
