Results 1 to 4 of 4
Thread: Idle Parameters
    Jul 2003
    Default Idle Parameters
    We have absolutely no idle parameters for the 4 cyl guys? Something like Minimum Idle airflow and some corrections?
    There is a guy I am tuning his Cobalt S/C and installed a set of cams and we need to solve an idle issue.
    This calibration is very very limited.
    Jul 2003
    Ah Sorry, this is an atlas PCM i believe. Can anyone move this post to the appropriate forum?
    Highlander, to be honest the P12 will get little attention these days, I can make a note of your request but don't expect anything soon.
    Jul 2003
    Ok Ross... thanks... will wait...
  1. what parameters need to be met to run idle catalyst effiency test?
    By skneeland in forum LL8 4.2L In-Line 6 - P10 PCM
    Last Post: February 20th, 2011, 03:24 AM
  2. OS 12612281 Doesn't have all idle parameters defined
    By Highlander in forum E37, E38 & E67 PFI ECM's
    Last Post: August 11th, 2009, 10:27 AM
  3. what parameters need to be met to run Idle Catalyst Efficiency Test?
    By skneeland in forum General (Petrol, Gas, Ethanol)
    Last Post: May 25th, 2009, 02:58 AM
  4. Any one know what parameters....
    By 98SS2836 in forum Gen III V8 Specific
    Last Post: January 16th, 2007, 05:01 AM
  5. Can you define these idle parameters?
    By Redline Motorsports in forum General (Petrol, Gas, Ethanol)
    Last Post: March 7th, 2006, 02:07 PM
