Results 1 to 2 of 2
Thread: New to efi live / wideband question
    Nov 2009
    Thumbs up New to efi live / wideband question
    I am picking up V1.2 EFI live, mostly for logging data, I want to learn a lot about the way my car runs ect, seems to have a good tune was done by a local guy that does a ton of vettes, here are my mods:
    1999 corvette with a built LS1:
    Forged lower end 9.5 compression Cartek stage II built heads / 921 springs / cam and a maggie blower with 10 lbs of boost.
    I have a few questions:
    How many things can be logged with 1.2?
    how many additional things can be added (w.b. ect)
    I plan on running a W.B., which setup is best for V1.2, I do not think I need a guage.
    What other additions are good? Should I get a MAP to read boost better? Exhaust temps? ect.
    Thanks in advance for any help
    Nov 2006
    Page 109 of the scan tool manual:
    Logging external data using FlashScan V1
    EFILive FlashScan interface is equipped with 3 separate inputs for capturing external data.
    The 2-pin terminal is a dedicated cold junction compensated k-type thermocouple input.
    The 3-pin terminal can accept up to 2 analog, 0V to 4.8V signals.
    Either of these two analog inputs can be used to log wide band O2 AFR data.
    LC-1 WBO2
  1. What wideband do you use with EFI Live???
    By Chuck CoW in forum General (Petrol, Gas, Ethanol)
    Last Post: December 23rd, 2011, 10:53 AM
  2. Please Help.. EFI Live-Adding Wideband PID
    By tatasta in forum Gen III V8 Specific
    Last Post: April 8th, 2009, 02:10 PM
  3. Which wideband are you using w/EFI Live?
    By TFZ_Z06 in forum Gen III V8 Specific
    Last Post: July 30th, 2008, 06:49 PM
  4. EFI live won't see wideband...???
    By rubbersidedown in forum Gen III V8 Specific
    Last Post: July 15th, 2008, 03:37 AM
  5. wideband and efi live
    By ZL1Killa in forum General (Petrol, Gas, Ethanol)
    Last Post: May 25th, 2006, 04:28 PM
