Results 1 to 7 of 7
Thread: New GT4094 Turbo
    New Member mtnmn's Avatar
    Nov 2009
    Default New GT4094 Turbo
    Help! How do I get EFILive to tell my ECM to stop looking for a VVT?
    It's locked in limp mode and keeps throwing P2564 since the ECM is looking for the variable vane turbo that is no longer there. I bought EFILive just to get rid of this issue - but I can't figure out how...
    Thanks in advance!
    2006 GMC Crew Cab Dually 4X4 LBZ
    All Seasons PCV mod, MBRP dual 4" exhaust, Finger, AFE Stage II Intake, FASS, Suncoast Transmission, FS2500, BFG All Terrain TA 235/85/16, BD Blow Off Valve, GT-4094 Turbo
    Aug 2009
    Go to: Engine Diagnostics, then DTC Enables and set everything having to do with VVT to "not reported".
    Nov 2009
    Quote Originally Posted by ILVSMOG View Post
    Thanks! That worked!
    Aug 2009
    Right on, enjoy! I've got a 4088r on my '07 dually, that '94 must be a monster! How does it do towing??
    Aug 2009
    BTW: just noticed in your sig that you have Finger Stick. When you get a chance, remove it and just turn off the EGR with EFI. The Finger Stick (allegedly) goofs with the MAF signal, and you don't need it now with EFI!
    Nov 2009
    It does quite well... I have a PPE Hot+2 on level 5 when I tow (I got the EFILive to get rid of the VVT codes - but I'm scared to screw with it for tuning: too complicated for me...) and she pulls pretty well... It has a little more lag down low - but once she's spooled it's pretty horny...
    Good to know on the finger - I'll yank it out...
    Lifetime Member LBZoom's Avatar
    Jun 2008
    Not to interfere, but if you ever get some spare time and decide you want to sit down with EFI live and get to know it better, the guys on here can get you pointed in the right direction. I'd say you might be a little happier with a DSP 5 position switch and a set of custom EFI tunes
    Peace Through Torque
    Punisher Performance DSP5 Tuning, PPE Dual CP3's, 68mm Fleece Cheetah, Punisher Built trans w/ Suncoast Parts, Airdog 165, SoCal 100% Overs, ARP Studs
    2013 NHRDA Sportsman World Champion
    www.PunisherPerformance.com
  1. Turbo LL8- Need advice!
    By projectile in forum LL8 4.2L In-Line 6 - P10 PCM
    Last Post: April 26th, 2011, 09:04 AM
  2. Closing turbo vanes for turbo braking?
    By Haulinbass02 in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: May 14th, 2009, 12:12 PM
  3. LMM Max turbo boost
    By bondurch in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: April 16th, 2009, 11:51 AM
  4. anyone have a sts turbo kit
    By pdasterly in forum Gen III V8 Specific
    Last Post: March 2nd, 2009, 12:27 AM
  5. STS Turbo
    By oztracktuning in forum Forced Induction and Nitrous Oxide (N20)
    Last Post: January 27th, 2007, 10:10 PM
