Page 1 of 3 123 LastLast
Results 1 to 10 of 30
Thread: Help connecting AEM wb to flashscan
    Dec 2005
    Default Help connecting AEM wb to flashscan
    I feel like a retard but oh well I need help. I have 1 blue wire and 1 white wire that I need to connect to flashscan box. Which plug do I use the 2 pin or 3 pin and also what wire goes to which pin. Sorry for the dumb question but I can't find any documentation on this. Also exactly how do I get the PID set up and ready for logging?
    Nov 2006
    Assuming you have the AEM 30-4100
    *WHITE <Analog Output>
    Connects to any auxiliary unit that accepts a 0-5 volt input.
    *BLUE <Serial Output>
    Connects to a RS-232 com port for hyper-terminal data logging.
    The white wire goes to EXT.AD+
    You may need to run a wire from EXT.AD- to chassis ground.
    The blue wire is for serial connection. (V2 only)
    LC-1 WBO2
    Dec 2005
    How do I know wt EXT.AD+ and EXT.AD- is? I have no diagrams or anything on this.
    Nov 2006
    LC-1 WBO2
    Dec 2005
    Thank you! I looked in my efi documentation for this and couldnt find it anywhere.
    Do you have V1 or V2...?
    If you have V2, turn it over, it has a decal showing the pins.
    Dec 2005
    V1.2
    In mr.prick's post, see the first image... this is in the scantool user manual pdf... included with your install of EFILive V7.5 software or from the link posted by mr.prick (his real name).
    Which model AEM do you have...?
    Does your AEM user manual give you an equation for converting V to AFR...?
    Dec 2005
    yea it's a 30-4100
  1. RR not connecting..need help
    By superspeed in forum RoadRunner Real-Time PCM Emulator
    Last Post: January 29th, 2009, 12:50 PM
  2. Connecting LC-1's
    By MyM8V8 in forum General (Petrol, Gas, Ethanol)
    Last Post: January 7th, 2009, 10:21 AM
  3. New help connecting to RR
    By 99ss in forum RoadRunner Real-Time PCM Emulator
    Last Post: August 25th, 2007, 11:57 AM
  4. connecting lc1 to v2
    By mr.prick in forum FlashScan V2
    Last Post: February 8th, 2007, 01:46 PM
  5. LM-1 connecting to V1
    By turbo lcc in forum General (Petrol, Gas, Ethanol)
    Last Post: January 27th, 2007, 11:06 AM
