Results 1 to 10 of 16
Thread: Injector Data for return style fuel system
    Jan 2006
    Default Injector Data for return style fuel system
    I just installed a fuel cell and new complete fuel system in my 99 Z28, nothing was reused. I now have a regulator mounted to the fuel rails and a return going back to the tank. Do I need to change anything with the injector tables for this? The pcm is still turning on the fuel pump but the ext reg is controlling pressure.
    Oct 2006
    Unless you have changed from a manifold referenced system to a non referenced or vice versa you will not need to change anything as long as the working pressures are the same.
    The Tremor at AIR
    B4001 has to be flat (same value in all cells) now since the manifold-referenced regulator now keeps the pressure difference across an injector constant...
    all cell values are equal to the value for MANVAC=0 in the spreadsheet.
    Jan 2006
    When is that needed, only when the regulator is between the fuel rails? What about with a corvette regulator back by the tank? I have my reg between my fuel rails on my car.
    The IFR table is flat when the FPR has an air hose connecting it to manifold pressure/vacuum (this is called "manifold referenced")...
    A manifold referenced FPR is typically located on a rail, or between the rails, and has a return line going back to the tank.
    The regulator located near/in fuel tank is not manifold referenced (and so has a sloped IFR table)...
    1997 LS1 Y-body uses a manifold referenced FPR.
    1998+ LS1 Y-body and 1998+ LS1 F-body use a non-referenced regulator.
    More info (if you are math inclined): showthread.php?t=4821
    If your FPR is between the rails, check that it has:
    - an air hose going to the intake manifold,
    - a return line back to the fuel tank.
    It should have both.
    This regulator keeps the pressure difference across any injector constant:
    if FPR base absolute pressure is FP+BARO, then:
    absolute pressure on top of injector = FP+BARO+MAP (since manifold referenced)
    absolute pressure on bottom of injector = MAP
    difference of absolute pressures = FP+BARO = constant (regardless of MAP) -> IFR table is same value all across ("flat").
    IFR is proportional to squareroot of pressure difference.
    (side note: absolute pressure = gauge pressure + BARO)
    Jan 2006
    I dont have - an air hose going to the intake manifold
    but do have a return going to the tank off the reg.
    Can you post a picture of that...
    Aug 2008
    Good info in here....
    FLASHSCAN V2 & AUTOCAL
    Does the FPR body have a port/nub that looks like a vac hose would fit...?
  1. How to: Program injector flow data from GPM to ECM using EFILive V2
    By DuramaxPowered in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: December 31st, 2012, 10:22 PM
  2. Can anyone decode this Greek? (Injector Data)
    By samh_08 in forum General (Petrol, Gas, Ethanol)
    Last Post: February 17th, 2010, 05:00 PM
  3. Injector Data
    Last Post: November 24th, 2009, 07:07 AM
  4. Injector flow rate data.
    By bballer182 in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: November 22nd, 2009, 04:55 PM
  5. ST-12: Engine Data Acquisition System
    By TLKSCHP in forum External A/D inputs
    Last Post: September 12th, 2007, 10:45 AM
