Results 1 to 8 of 8
Thread: Injector Data
    Jan 2006
    Default Injector Data
    I bought Greg's DVD and have injectors listed on the spread sheet but the colums dont match values in efi live? What am I over looking?
    Apr 2008
    post pic of the table.
    Regards,
    Odd Boy
    Nov 2006
    Is the table horizontal instead of vertical?
    If so then use the conversion tab (Ctrl+Alt+Enter)
    LC-1 WBO2
    Jan 2006
    The data in efi live doesnt match the spreadsheet. For example the small pulse adjust, whats listed on the spreadsheet doesnt match efi live for me to copy and paste.
    Jul 2005
    is it just the issue of displayed resolution in the spreadsheet or in efi?
    Apr 2009
    Quote Originally Posted by minytrker View Post
    PLEASE WATCH THE DVD!
    It walks you through the proper method for using the raw small pulse adjust data and interpolating it correctly into your PCM's breakpoints in the table.
    ~Greg
    Calibrated Success - EFI Training and Tuning Done Right
    GM Beginner's Guide DVD available now through Summit!
    Engine Management: Advanced Tuning - Amazon's best deal for the EFI crowd.
    Jan 2006
    Quote Originally Posted by eficalibrator View Post
    I watched again and that did help a little, all though an example using efi would have been nice on the dvd instead of just showing the table. I use both hpt and efi and its still really hard for me to flip flop axis on tables in my head.
    I also noticed there was more info on the hpt excel sheet vs efi one, i caught it in the video and had to get some info off the hpt excel sheet even though im using efi.
    Jul 2005
    in excel, if you copy the data you want, and then do paste special, and check the 'transpose' option, it will convert column<->row for ya.
  1. How to: Program injector flow data from GPM to ECM using EFILive V2
    By DuramaxPowered in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: December 31st, 2012, 10:22 PM
  2. Can anyone decode this Greek? (Injector Data)
    By samh_08 in forum General (Petrol, Gas, Ethanol)
    Last Post: February 17th, 2010, 05:00 PM
  3. Injector Data for return style fuel system
    By minytrker in forum Gen III V8 Specific
    Last Post: November 26th, 2009, 03:36 PM
  4. Injector flow rate data.
    By bballer182 in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: November 22nd, 2009, 04:55 PM
  5. Injector offsets and injector slopes....
    By Redline Motorsports in forum General (Petrol, Gas, Ethanol)
    Last Post: June 19th, 2006, 02:32 AM
