Results 1 to 10 of 17
Thread: Gear changes
    Lifetime Member jfpilla's Avatar
    Default Gear changes
    Will there be a gear scaling feature?
    You mean like this? Or something else?
    Paul,
    For some reason I can't get a screenshot up. I'm mailing two docs.
    Joe
    Default Re: Gear changes
    Quote Originally Posted by jfpilla
    Or do you mean re-scaling of the speed based shift points?.
    Paul,
    Joe
    Nothing has come through yet Joe....
    Paul,
    You have total of three emails. Each to a different address.
    Joe
    Quote Originally Posted by GMPX
    Edit has a feature which rescales shift points, both rpm and vss. It also "fixes" the TCC slip calculations.
    The above is used when rear gears are changed or slip codes are set.
    The shift point changes get you closer, but are not really important since they need tweaking anyway.
    I'm certain that there are some on this forum that have used it?
    Lifetime Member Steve Bryant's Avatar
    Feb 2004
    Joe,
    Are you talking about changing the rear axle ratio (ring and pinon gears) or scale the speedometer reading for different size tires? FlashScan can adjust for this kind of thing. I'm trying to understand your question too.
    Steve
    Quote Originally Posted by Steve Bryant
    Joe,
    Steve
    No tire changes. C5's only need slip calculation changes, when a rear gear change is made, to a lower gear the trans input and outputs don't match. The PCM thinks the trans is slipping and sets codes and goes into safe mode and raises trans pressure. Very hard shifts.
    Here it is.
  1. What gear am I in??
    By bobbycollier in forum General (Petrol, Gas, Ethanol)
    Last Post: September 9th, 2009, 04:06 AM
  2. 05 5.3 gear swap
    By rgullett83 in forum Gen III V8 Specific
    Last Post: March 24th, 2008, 05:24 PM
  3. says gear set to zero
    By TLKSCHP in forum General (Petrol, Gas, Ethanol)
    Last Post: May 9th, 2007, 10:13 AM
  4. Gear worksheet
    Last Post: January 12th, 2007, 03:03 AM
  5. O/T: Top Gear is returning!
    By Garry in forum Lounge
    Last Post: December 19th, 2006, 06:38 PM
