need some advice on setting trans pressures d0701,d0702,d0703
pressures weren't an issue until i herd strange noises from my 4l60e i got the box stripped and found all clutches buckled and worn including 2nd band?
so $4500 dollars later my trans repairer thinks it could be the maggie or through program i haven't altered any pressure settings. still factory settings only shift at vss due to 3.91 installation
