Page 5 of 10 FirstFirst ... 34567 ... LastLast
Results 41 to 50 of 95
Thread: E38 / E67 Custom OS Beta release
  1. #41
    Dec 2007
    Anyone use this Beta yet?
  2. #42
    Dec 2007
    Yes...works well!
  3. #43
    Dec 2007
    Where did you get the pins/stuff to put in the PCM and how hard was it to install?
    What are you running nitrous, F/I etc.? What vehicle?
  4. #44
    Dec 2007
    Quote Originally Posted by SRT10KLLR View Post
    Details on installation here:
    http://forum.efilive.com/showpost.ph...8&postcount=15
    Plus download the tutorial that appears in an earlier post in this thread. All details in there. Not difficult at all.
    On terminals, where are you?
    No gas. No FI. 08 Corvette powertrain.
    Have used the COS to switch E85 in and out, plus select a different timing map and/or different fueling. So yes good for running some gas or FI.
    Cheers.
  5. #45
    Dec 2007
    I am in southern California and looking to get this for adjusting timing/fuel on a 2010 Camaro with nitrous.
    This is my first rodeo so any help would be appreciated.
    Jimmy
  6. #46
    Lifetime Member JezzaB's Avatar
    Nov 2006
    Gave it a little try today. set the Ethanol table to -10deg and it pulls this nicely from the commanded spark but I noticed it wasnt changing to my commanded PE (ethanol) table and was only using the normal table.
    Must of missed something. Ill keep looking.
  7. #47
    Jul 2003
    We need a 2-step for this.
  8. #48
    Dec 2007
    Quote Originally Posted by JezzaB View Post
    mmmm...never checked the PE table switchover.
  9. #49
    Can't think what you may have missed, but I know the PE switch over is working ok because these were tested on some LPG systems down here in Vic with different PE values in mind.
    You must have not read the initial post:
    Before you ask clause!!
    No feature requests, these custom OS's have already proven in the field to be perfectly suited for the applications in mind.
  10. #50
    Jul 2003
    I was NOT requesting jaja... Oh Ross... You always jump up with me
    But a Custom OS which takes input from the clutch pedal would be great for WOT shifting... JAJAJAJA
  1. 98 Controllers Missing from New Beta Release
    Last Post: March 23rd, 2008, 11:03 AM
  2. 3/18/08 What do I need to have to be prepared for the new beta release
    By Kevin Doe in forum FlashScan V2 BB Logging
    Last Post: March 23rd, 2008, 03:56 AM
  3. V2 Black Box Logging - Beta Release
    By Blacky in forum FlashScan V2
    Last Post: November 27th, 2007, 09:11 PM
