I have V1 "Blackbox" and have scanned an 06 lly with it. Can I scan my 08 LMM with it, check and reset codes? I utilize the V1 for my 04.5, but I have had some codes on my 08 LMM and would like to check these.
Never mind I found my answer.
15 ZL1 Camaro, 580HP Stock, no tune
12 LML Extended Cab 4x4, H&S'd(want EFI), deleted and stock tune
08 LMM CrewCab 4x4 Bone Stock, EFI'd and deleted with Tow Tune w/ Exhaust Brake
04.5 LLY Extended Cab 4x4 with Many Mods, EFI'd, sold
For others wondering, the answer is no, the V1 will not talk to the LBZ or LMM, the V1 was designed before GM had switched over to using the CAN bus.
So wondering if the 2006 LLY would be read. Wondering since I hear they were Bosch ECM.
Brian
2007.5 GMT-900 Chevrolet Silverado 2500HD CC/LB LTZ 4x4 Summit White.
With the LMM Duramax 365hp/660tq, MW7 Allison 1000 6-speed
EFILive LMM DSP5 Settings, 500HP, 450HP, 400HP,Tow with Turbine Brake, and Stock HP.
UA Steamfitter, Local 136 Evansville, IN - Remember if you want to play you got to pay.
If it's the Bosch ECM then no, that is when they moved to CAN.
