Results 1 to 4 of 4
Thread: Cal_Link
    Member Big D's Avatar
    Aug 2007
    Default Cal_Link
    anyone have a calibration link for the LL8 they are willing to share
    Making tires smoke since 1994
    Grand Junction CO
    Sure man, here's mine. Not complete but pretty close, as close as can be had with the available PIDs.
    Now if I could just figure out how to get the P10 to report a commanded AFR/EQ Ratio and a valid Load Pct Id be set. Any suggestions?
    Aug 2007
    Thanks a million! I started to create my own but ran out of time. X2 on the afr and load pct.
    Grand Junction CO
    No prob man, Ive got my 02 I6 tuned to where I like it but its a little lean when I lay into it cruising on the hwy. WOT and PE are almost dead on to what Im commanding in the tables and cruise is a hair lean, about 14.8-15.2 at cruise with low load, what Im trying to dial in is when Im going 75 cruising at 15.0afr and go up a hill, MAP increases so fueling should to and its not going back to 14.7 (or even better 14.5) like Id like it to.
    So hopefully we'll figure this AFR and Load_Pct thing out soon, need to dial the final VE table stuff in and swap the WBO2 to my LS2 and start working on it.
  1. Bosch-Suggestion for continuity-cal_link
    Last Post: July 27th, 2009, 03:20 PM
  2. Upto date Cal_link file
    By hquick in forum RoadRunner Real-Time PCM Emulator
    Last Post: June 24th, 2008, 05:33 PM
  3. cal_link advise
    By mr.prick in forum RoadRunner Real-Time PCM Emulator
    Last Post: November 1st, 2007, 02:58 PM
