Results 1 to 5 of 5
Thread: Build 88
    Dec 2006
    Default Build 88
    I currently have V1 cable and my current build date is Build 74, everytime I have tried to update to Build 88 nothing happens. Either V1 does not update past build 74 or, more than likely, I am doing something wrong.
    Nov 2006
    Are you using the updater or did you download it manually?
    LC-1 WBO2
    Dec 2006
    I used the instructions on EFILive; start, programs, efilive, 7.5.5, tools, check for new updates
    Oct 2004
    Quite some time ago now we changed the installer behind the EFILive
    software, which includes a different update component. The installer we
    used prior to this did deliver on the promise of auto updating so we had to
    change to another product.
    I can't recall now what version the changeover occurred, but if you are getting errors like host not found or something then this will be the issue. We would recommend downloading the Build 88 and installing that anyway, or the Build 99 pre-release.
    Andrew
    EFILive Crew
    Dec 2006
    I downloaded build 88 and every thing is fine. Thanks for your help.
  1. Replies: 50
    Last Post: March 15th, 2009, 03:00 PM
  2. 7.5.4 build 66
    By eboggs_jkvl in forum FlashScan V2
    Last Post: October 22nd, 2008, 10:22 AM
