Results 1 to 4 of 4
Thread: RPM Threshold for Airflow Calc {B0120}:
    Aug 2009
    Default RPM Threshold for Airflow Calc {B0120}:
    I have a L98 6.0 Chevy lumina 2008 (Holden) e38 ecm. I can't seem to find B0120. How do i ensure that i stay in MAF across the rpm range. I am busy calibrating the ve tables as per the tutorials and having some success, i want to calibrate the MAF on Friday and just want to be sure that i have not missed anything
    Mark
    Aug 2008
    {b8024} & {b8025}
    FLASHSCAN V2 & AUTOCAL
    Aug 2009
    gameover, thank you, i would never have found it. should i set the values higher when i am setting vve (MAF is disabled as per tutorial) and once vve are calibrated and i start calibrating maf go to 400rpm for full MAF
    Aug 2008
    To tune MAF only set B8024 = 400 & B8025 = 10
  1. Desired airflow won't equal measured airflow
    By Ryan in forum Gen III V8 Specific
    Last Post: June 4th, 2008, 09:17 AM
  2. Replies: 12
    Last Post: December 13th, 2007, 11:52 AM
  3. B0120 ?
    By DrX in forum General (Petrol, Gas, Ethanol)
    Last Post: October 24th, 2006, 03:05 AM
  4. Question about calculated airflow vs. measured airflow
    By JR_VETTE in forum General (Petrol, Gas, Ethanol)
    Last Post: October 1st, 2006, 05:37 PM
  5. rpm threshold
    By NviouSS in forum General (Petrol, Gas, Ethanol)
    Last Post: October 14th, 2005, 06:36 PM
