Results 1 to 10 of 12
Thread: checking wideband accuracy with the narrowband?
    Jun 2007
    Default checking wideband accuracy with the narrowband?
    I'd imaging you can check wideband accuracy with the narrowband around stoich?
    Anybody have a log with wideband with narrowband o2 pid's. I'd like to look at it? I have one narrowband o2 sensor that just stays .4 volts most of the time and I'm pretty sure thats bad and my other o2 sensor doesn't seem to follow the wideband correctly.
    This graph would represent the ls1 narrowband voltage table correct?
    9.8@150 . LQ4 Turbonetics Billet 7575@18psi, 6 speed, non-intercooled with meth. Speed Density, open loop, no PE.
    With COS5 I set B3647 to give semi-open loop (which uses STFT to trim to stoich)...
    Look at how AFR_WBOS1 oscillates tightly around AFR...
    HO2S11 = OEM NBO2 signal, HO2S21 = LC-1 NBO2 signal.
    Oct 2006
    Narrowband voltage is more like the pic I have attached, & is effected by the exhaust temp.
    The Tremor at AIR
    Jun 2007
    Quote Originally Posted by 5.7ute View Post
    Thats quite a vertical line there by stoich!
    Joe, thanks for the info. On that last log you posted, even though you named the file OLSD_xxxx you are also doing closed loop or partial closed loop in that log too correct? Sure looks like it. I added the pid calc.afr.lc11 to your log and seems like that isn't right, seems to oscillate too lean compared to the narrowbands. Is that the right pid to view your wideband afr?
    Sorry I'm new to this.
    Oct 2006
    Quote Originally Posted by ryans1000 View Post
    Yep. Thats why we have B4105/B4107.
    The Tremor at AIR
    Jul 2007
    I had a look at trying use the NB like a WB, by setting up a lookup table with averaged NB voltages. What I found was that the NB never really read the same voltages for the same given conditions over time. I doubt very much that you could use them to check anything other than an averaged "switch point". This is about the only thing the NB does well, switch from higher to lower voltages. The actual voltage levels themselves mean very little when taken on their own.
    I guess the closest you could do is to is to average a very large amount of NB data to tell if the WB is in the same ball park reading. But I think that that's as close as you would get. The idea of any of the graphs giving a true indication of voltage vs AFR, would be a "general response" curve and not based on actual calibrated data. All the NB has to do is switch quickly to indicate a rich or lean condition, and provide an average of about 450mV via the switching. This will then allow the ECM to correct the average mixtures to the correct ratios.
    Simon.
    I had programmed my LC-1 to give AFR = V + 11, which is CALC.AFR_WB_A1 in the calc_pids.txt I attached.
    Jun 2007
    Ohh I see. I missed see the pid file you attached . Makes sense now.
    Here's the log... I searched thru a whole pile of old log files to find it...
    This was with FSV1 and LC-1...
    My LC-1 is providing the NBO2 "equivalent" signal.
  1. Narrowband Interchangable?
    By LastCall in forum Gen III V8 Specific
    Last Post: May 5th, 2010, 02:18 AM
  2. Turning off PE...wideband accuracy???
    Last Post: August 20th, 2008, 07:16 PM
  3. Problem with wideband A/D accuracy
    By thunder550 in forum External A/D inputs
    Last Post: November 19th, 2007, 10:14 PM
  4. Narrowband Simulation Wiring
    By NewV in forum Gen III V8 Specific
    Last Post: January 12th, 2007, 12:53 PM
  5. Logging w/out a Narrowband...
    Last Post: December 27th, 2006, 02:33 PM
