I just made these logs and my VE is still a bit off. Maybe bc I was logging in the rain yesterday with zero traction. Just applied the new cells from my map to my VE without smoothing. Tell me what you think. I'll work with this a bit but i'm gonna redo my sd log on dry road i guess. My AFR is way far off.
The VE looks rich, I would recommend fixing the open loop fuel table with a constant no. like 12.5 or 13, since your car needs fuel. Make it constant from low map to 85.
I let off of it bc actual AFR was like 13.3. I never adjusted the OL fuel table so it's should be stock. I think it's like 14.63 . Should I put the whole table to 12.5 or just the high map cells and put lower ones at 13 or something?
