Results 1 to 10 of 16
Thread: EFI Connection Cruise Control Signal Interface
    Aug 2006
    Default EFI Connection Cruise Control Signal Interface
    In addition to the tap signal interface, we're also working on a cruise signal interface. Newer ECMs and BCMs require a varying voltage (through one wire) to indicate the driver's cruise signal commands. Early (and aftermarket) cruise control switches pulse 12V to indicate On/Off, Set/Coast, Accel/Resume. This interface will be much like the tap signal interface with custom CNC enclosure using a Delphi header/connector solution.
    5/3/2011 EDIT...here is the completed module. EFI# 110-00024.
    24x LS1 PCM on Early Small-Block Chevy and LT1/LT4
    http://www.eficonnection.com
    Jul 2003
    Mike you are doing some hardcore stuff!!!!!!
    Senior Member doubledip's Avatar
    May 2008
    with this box can it be wired into a conversion that is running a e38 and t43 and then you can run a 2 wire switch (the type that varies the voltage depending on fucntion required) ? as well as the more traditional aftermarket switch which just momentary puts 12v down seperate wires for different functions?
    E38's got to love them
    E40's hate 'em
    LS1's is there anything it wont work on
    Holden VE SSV - GEN46L
    www.ultimateconversionwiring.com.au
    www.dualflash.com.au
    Aug 2006
    Inputs are 12v On/Off, 12v Set/Coast, 12v Accel/Resume. Output is varying voltage to ECM/BCM. This is the opposite of what you are requesting.
    You could use Rostra type cruise switches with this module.
    May 2009
    Congratulations. Glad Ian helped out!
    Trailblazer "RS" 5.3L 6L80 4x4 & '07 TBSS LS2 6L90 AWD
    Aug 2006
    Update.
    Here's the prototype enclosure...before anodize and artwork.
    Aug 2006
    Here is the completed module. EFI# 110-00024.
    Very nicely made.
    Jul 2011
    here is my question.
    I have put a new outlander steering wheel in my 2000 eclipse.
    the steering wheel is multifuctional with audio and cruise controls.
    for the audio I have an interface.
    but the cruise control still doesn't work.
    I have 2 wires in my sterring wheel for the signal controls.
    if I put this interface in my car can I use my aftermarket cruise control with the steering wheel switches?
    and how to wire it up to the 2 wires in my steering wheel?
    Aug 2006
    Quote Originally Posted by maxxxie View Post
    Probably not, but I'm unfamilar with the wiring (and resistance values) of the cruise control system you are working with.
  1. EFI Connection Tap Signal Interface
    Last Post: May 3rd, 2011, 02:45 AM
  2. Cruise Control Surging
    By ViciousKnid in forum Gen III V8 Specific
    Last Post: February 9th, 2010, 05:55 AM
  3. Lean Cruise and Cruise Control
    By neil in forum Tuning For Economy
    Last Post: July 9th, 2007, 09:42 PM
  4. What causes surgin/cruise control?
    By pkincy in forum General (Petrol, Gas, Ethanol)
    Last Post: January 29th, 2006, 01:57 PM
  5. Cruise Control Effect
    By eboggs_jkvl in forum General (Petrol, Gas, Ethanol)
    Last Post: December 27th, 2005, 08:15 AM
