Results 1 to 10 of 10
Thread: Carbureted LT1 Runs on LS1 PCM
    Aug 2006
    Default Carbureted LT1 Runs on LS1 PCM
    Today we tested the LS1 PCM as an ignition controller with a carbureted LT1 engine. We turned the key for the first time today; the engine started on the first crank. Throttle response is excellent. We're looking forward to the installation in a vehicle and 4L60E (or 4L80E) transmission control.
    Video: Click to view 10MB video
    Tuned with EFILive. 2002 Camaro LS1 calibration.
    Crank and cam signal components.
    24x LS1 PCM on Early Small-Block Chevy and LT1/LT4
    http://www.eficonnection.com
    I have to say, your conversion kit is simply awesome. I sort of wish I had an LT1 to convert over, but then I go into the garage and take the SS for a drive...6.0 liters of pure GM small block fury with AWD just cant be beat.
    Now a Syclone converted would be cool...
    Did you go with a carb due to certain racing classes not allowing EFI?
    Aug 2006
    I think a carburetor is blasphemous! (to EFI) But to satisify curiousity and to show that the LS1 PCM is not just a fuel management system, we wanted to get a carbureted engine running with the LS1 PCM.
    - an accurate crank/ignition signal
    - tuning to 8,000 rpm
    - IAT input (eliminate hot/cold starting issues)
    - CTS input (eliminate hot/cold starting issues)
    - 4L60E/4L80E control
    - tach output
    - VSS output
    - up to two knock sensors
    - and software that allows real-time tuning, data acquisition, data tracing, etc (thank you EFILive)
    It's a marvelous ignition controller! As far as I know, the aftermarket has nothing on the LS1 PCM as an ignition controller.
    Good job... looks like you can get the LS1 PCM to run just about anything.
    Lifetime Member Mr. P.'s Avatar
    May 2007
    Just Awesome! Buh-Bye Optispark!
    Mr. P.
    Jan 2009
    That's awesome.
    Another application that comes to mind is a Fox body LS3, carbed, 4L60E, with LS1 PCM to control the trans and ignition. That would be cool.
    BTW how did you figure you how to mount the TP sensor on the carb?
    Aug 2006
    Quote Originally Posted by Eric Fischer View Post
    It's just an 80s GM TPS sensor with a cable to pull it. Same idea as what you get from TCI when installing one of their transmission controllers.
    Lifetime Member Doc's Avatar
    Oct 2005
    As having been involved with the tuning and installation of 3 of these conversions using EFI Connection's kit on customer's cars thru my shop I can attest to the quality of the componets contained there in.
    An execellent alternative for the LTx crowd. Great job Mike and Co.
    Doc
    www.efialchemy.com
    www.greatamericancarwar.com
    May 2014
    Default carbureted ls1 1998 camaro ss pcm 4l60e trans
    Quote Originally Posted by S10Wildside View Post
    - tach output
    - VSS output
    what do i need to do for a carbureted ls1, 1998 camaro ss 5.7 ecu, 4160e trans. mild cam.3 bar map. running no maf senor conversion.
    what senors do i need to keep.
    what tuning i need to do.
    email me at perri00c@gmail.com
  1. 0411 with 98 L-29 454 runs terrible....
    By LS1_Dragster in forum Gen III V8 Specific
    Last Post: March 24th, 2009, 04:15 PM
  2. procharged 383 with '96 efi only runs 14's @ 96
    By tommytooslow in forum Vortec V6/V8 Specific
    Last Post: February 20th, 2009, 05:47 PM
  3. 1/6th scale SBC that runs...!!!
    By joecar in forum Lounge
    Last Post: February 19th, 2009, 07:08 AM
  4. Dyno runs / how to lock tcc ?
    By tblu92 in forum Gen III V8 Specific
    Last Post: October 28th, 2008, 05:03 PM
  5. 2nd start runs lean
    Last Post: January 12th, 2008, 09:23 AM
