i just installed the swich when i cranked the truck the low oil pressure and battery not charging messages poped up anyone know that i did wrong?
Did you convert YOUR trucks stock tune to DSP5 or use another that somebody else sent you from another truck?
You will run in to trouble if you flash in tunes from other trucks that are not the exact same model as yours.
