Results 1 to 2 of 2
Thread: low pressure adjustments?
    Aug 2008
    Default low pressure adjustments?
    d1101-d1102-d1103 would these tables be deductions for pressure when manually selecting drive and in normal mode ?
    No... D1101-7 are the limits of the adjustment delta that the PCM/TCM can make to the learned pressure... I'm not too sure how this all works.
    For modifying pressure when you manually select Drive, see D1501-3 and maybe also D1504-5.
  1. maf adjustments
    By smslyguy in forum Gen III V8 Specific
    Last Post: June 10th, 2010, 04:11 AM
  2. Timing adjustments
    By JASON11LS1 in forum Gen IV V8 Specific
    Last Post: July 24th, 2009, 12:53 PM
  3. Need help with understanding MAF adjustments.
    By Redline Motorsports in forum General (Petrol, Gas, Ethanol)
    Last Post: January 18th, 2009, 03:38 PM
  4. B4521 Max STIT adjustments?
    By PRAY in forum Gen III V8 Specific
    Last Post: January 4th, 2009, 03:15 AM
  5. V2 AD1 voltage adjustments?
    Last Post: April 24th, 2007, 08:23 AM
