Hi,
not sure if this was covered in the past:
I noticed that while logging MAP and MAF (lb/min) both
have identical values under all conditions, for example
at WOT both have 29.8. I currently have V7.2.2 build 236
and obdiiV7.2.2 build 374. It looks like th MAF readings
is wrong, the MAP readings are correct (what you would expect under
various conditions).
Gert
