Results 1 to 7 of 7
Thread: Wasnt sure how hard EFI was???
    Oct 2009
    Default Wasnt sure how hard EFI was???
    I have pretty much give up on purchasing EFI. You guys said it was easy, hell I'm having problems with the practice session. I tried to set up the evaluation and I did it like the directions and it kept saying it was an invalid key. I think 800 might be to much to spend to find out I'll regret it later. Any help will be greatly appreciated I'm open to suggestions
    Oct 2004
    If you haven't purchased yet what key are you expecting to enter to register?
    Andrew
    EFILive Crew
    Lifetime Member Aloicious's Avatar
    Nov 2007
    Quote Originally Posted by cjms View Post
    key? what directions are you referring to? the software you download is the actual program, so its expecting you to put in the cable's serial # and other information to use it. before you buy it, its basically just to play with and examine how the software works. try just hitting cancel or something if it asks for a serial # or key # or something, then go to holdencrazy.com and download some tunes to look at, you can see the tables that are used, see how they are altered, etc, etc. and see how you like the actual program.
    1996 c1500 gen1e 5.7L - the "LS31", 24x CNP, LS2 coils, modified T56, 12200411PCM running COS3, zz4 cam, custom MPFI, etc. coming soon: Twin Turbos
    Oct 2009
    I was refering to the EFI Live V4 evaluation, I was under impression you could use this to tinker with loaded tunes to practice on. I clicked on the section for a free evaluation license but it would not accept it.
    Oct 2004
    Moved to correct section of forum.
    Andrew
    EFILive Crew
    Oct 2004
    The details must be entered exactly as they are show on the eval license (same case). Do not enter any details not show as this will cause the license to be invalid.
    This product is also not a tuning tool, it is only an OBDI/ALDL data logger/scanner.
    Andrew
    EFILive Crew
    Nov 2007
    my mistake, I thought you were talking about 7.5
  1. Hard to start when hot
    By W_D_R in forum General (Petrol, Gas, Ethanol)
    Last Post: March 30th, 2010, 01:26 PM
  2. EFI hard limits B0202
    By sweetdiesel in forum Duramax LB7
    Last Post: January 23rd, 2010, 03:47 PM
  3. what is a hard start?
    By mr.prick in forum RoadRunner Real-Time PCM Emulator
    Last Post: September 23rd, 2007, 04:02 AM
  4. would this be hard
    By zrx1200 in forum Custom Operating Systems
    Last Post: August 7th, 2006, 08:29 AM
