the problem is when your runing the pe mode nothing is monitering what is happening with the motor. its just going off what ever the ve table says. so for any change in the envirorment the compurter is to stupid in a sence to adjust anything. well if the software would let you adjust the o2 volts from 0-1.5v to 0-5 volts, then you sould run closed loop and it would make happen what ever you are comanding. for instence if it went lean it would at least try to change it. just like stft but all the time. i such at spelling sorry.
