Results 1 to 6 of 6
Thread: Vortec 350/ Black box
    Mar 2008
    Default Vortec 350/ Black box
    Is it worth changing the factory tune on this PCM? I have a '98 Z71, almost entirely stock with the exception of dual exhaust (factory 2 into 1 muffler removed for 2 mufflers), a descreen MAF, and removed airbox. I manage 16.5-17.5 mpg on pure highway runs and summer grade gas, but mix driving, at least in the winter is horrible at 13-14mpg.
    I know the 411 swap is common, and fairly simple - but is it worth it in my case (truck will not be modded beyond what it has been other than maybe the throttle blase). Or will sticking with the black box pcm get me by - and is it worth spending the license on?
    Thank you
    May 2008
    Yes, absolutely, my 97 runs so much better and smoother. The transmission shifts far better too.
    Lee
    230" Dragster - 2000 LS1, 02020003 Speed Density, PRC 2.5 Heads,
    MS3 Cam 237/242 .603/.609, Vic Jr. intake, Holley 1000CFM TB,
    PowerGlide, 5000 stall converter. 8.70@154 MPH
    My Projects Homepage: http://www.horsepowerracing.com
    Mar 2008
    Out of curiousity, did you use the base tune from the '01-'02 Express van, or did you modify it?
    Lifetime Member Aloicious's Avatar
    Nov 2007
    Quote Originally Posted by 99TransAmls16spd View Post
    if you do your own tuning, the PCM swap is by far the best thing you can do for the truck. I love mine, the 411 and efilive are the best mod I've done yet. if you aren't going to do your own tuning, then the gains are negligable. the main gain from the 411 is the vast amount of control you'll get vs. the blackbox.
    since you mentioned spending a liscense, I'll assume you plan on doing your own tuning, and I would highly recommend it.
    May 2008
    I modified it, stock tune wouldnt run very well since I had engine mods done.
    Lee
    Aug 2007
    change to the 411, my truck shifts so much better, and plus I can access the lean cruise stuff to help with gas mileage.
    2005 chevy silverado, duramax tuned with efilive
    1997 Saturn sc2 turbo, tuned with megasquirt on e85
    2000 s-10 turbo'd tuned with efilive on e85
  1. vortec v6 to vortec v8 swap
    By grezzmky in forum Vortec V6/V8 Specific
    Last Post: September 21st, 2009, 05:49 AM
  2. SD on a black box OS?
    By Supercharged111 in forum Vortec V6/V8 Specific
    Last Post: April 12th, 2009, 03:50 AM
  3. MAF off on black box
    By pullincrazy88 in forum Gen IV V8 Specific
    Last Post: March 21st, 2009, 05:44 AM
  4. V2 Black Box data logging*vortec pid's*
    By GAMEOVER in forum Vortec V6/V8 Specific
    Last Post: October 7th, 2008, 04:01 AM
  5. Black Box
    By TAQuickness in forum General (Petrol, Gas, Ethanol)
    Last Post: January 23rd, 2005, 03:33 PM
