Results 1 to 3 of 3
Thread: Speedo correcting healp
    Junior Member Sixes350's Avatar
    Oct 2007
    Default Speedo correcting healp
    I have just installed a 3.91 diff into my M6 (was 3.46)
    Speedo was correct before the upgrade. I then changed the settings using the "Speedo correction" button and I cant get my dial to sit anywhere near what I am doing. At last calculation the speedo displayed 173km/h when I was doing 100km/h (GPS speed)
    Any help would be much appreciated on what I have done wrong.
    Current parameters below (Speedo shows 140km/h when doing 80km/h)
    H0101 - 19290
    H0102 - 10.0
    H0103 - 3.91
    H0104 - 1929.0013
    H0105 - 6226
    H0106 - 79535
    H0107 - 0.04
    Tyre size is 235/40/18
    Would using the Speedo fine tuning function help?
    2004 VY SS M6 Ute. Stock 5.7lt LS1, 80mm TB, Tri Y extractors to twin 2.5" exhaust, 3.9 diff. NGK Iridium plugs, 9.5mm leads, DuSpeed OTR
    Dual AEM WBO2, V2 EFILive
    try these's
    H0101 32793
    H0102 17.0000
    H0103 3.910
    H0104 1929.0013
    H0105 6226
    H0106 79535
    H0107 0.04
    330 rwkw EFILIVE OS 01290005 SD Cam / Head Tuned 6 speed VY SS Commodore
    10/71 Blown 572 Big Block Chev HQ 2 Door Monaro
    GM Performance Centre
    Busselton WA
    AUSTRALIA
    Phone: 0447 003050
    Oct 2007
    Thanks for the help. I see what my main problem was, H0102
    Cheers again!
  1. Speedo calibration VSS in Scan not same as speedo
    By maudyZ28 in forum 4speed RWD/FWD Transmission Tuning (incl T42)
    Last Post: April 23rd, 2010, 01:47 PM
  2. Correcting MAF Flow issue
    By Cougar281 in forum Diesel
    Last Post: March 19th, 2008, 02:26 PM
  3. Speedo Help
    By Dale in forum General (Petrol, Gas, Ethanol)
    Last Post: November 29th, 2007, 03:05 PM
  4. Replies: 3
    Last Post: September 23rd, 2007, 06:01 AM
  5. speedo Q's
    By RUTAN TA in forum General (Petrol, Gas, Ethanol)
    Last Post: January 28th, 2007, 08:21 AM
