Results 1 to 3 of 3
Thread: to cold to tune?
    Lifetime Member smslyguy's Avatar
    Oct 2008
    Default to cold to tune?
    Is there a temp at which it is just to cold to tune your engine? Or can you tune in any given temperature?
    2001 camaro z28 ss vert with factory slp upgrades, Hooker long tubes, 3"y-pipe to a 4" muffler, ,airlid,s.s.r.a. ,t.c.bypass,descreened m.a.f. 232/234 .595,.598 +2 comp cam with ported and polished stock heads with .650 lift dual springs and a bowl grind. tuned with EFI Live. All combined to achieve 29 m.p.g. and 399 r.w.h.p. with 384 lbs of torque. sold...
    Now own a 2015 1LE camaro
    Jul 2008
    Technically it should make little to no difference..of course assuming you do most of your tuning at normal engine operating temperature.
    If you stay in closed-loop, the first few minutes always see unusual' fuel trims anyway. That, and it may reveal how well some of your Idle Airflow Tables are modeled.
    In general, I prefer not to tune when temperatures are below freezing or when they are over 100F. This is personal preference. When it is cold, oil life becomes reduced (have logged oil life pid) and personally my tires feel like bricks. Even driving normally, at temps below 40F..I have little to no traction. WOT I would be in the ditch!
    At temperatures above 100F (and high DA's) I feel a performance loss and am more prone to pinging and/or detonation. Yes, the Spark IAT table adjusts timing to accommodate, but again personal preference.
    Basically I use the same rules you might use if you are a runner or jogger. Perfect running weather is about 40-60F..works the same for my car. Try tuning around a constant ECT and IAT. That strategy has worked for me.
    Oct 2008
    Thanks for the info weatherman, it was helpful.
  1. Cold Weather Tune
    By 2500ak in forum Gen III V8 Specific
    Last Post: February 2nd, 2010, 05:55 AM
  2. Cold weather=Rich tune???
    By coryhussey in forum Gen III V8 Specific
    Last Post: January 17th, 2009, 11:36 AM
  3. ECT too cold?
    Last Post: February 12th, 2008, 06:19 PM
  4. Slight hesitation when cold after VE and MAF Tune
    Last Post: August 29th, 2006, 09:57 AM
  5. Cold Start
    By pomona in forum General (Petrol, Gas, Ethanol)
    Last Post: April 28th, 2005, 07:11 PM
