Results 1 to 4 of 4
Thread: DSP2 switch not working
    Dec 2009
    Default DSP2 switch not working
    i was wondering can u ground the switch to any metal on the truck or does it have to go to pin 37 as the ground. reason i ask is the guy that gave me the pin only gave me one and then said to just ground the other wire.
    Nov 2006
    You can strip the tip of the wire (1/32") and push it into the PCM slot.
    I did this with my fuel pressure sensor wire until I bought the pin, it worked fine.
    LC-1 WBO2
    Dec 2009
    ok. good idea, i will do that...
    Thank you
    Any ground seems to work ok. But technically the ECM's ground is ideal.
  1. Going from DSP2 switch to DSP5 switch
    By Dmax15 in forum Duramax LB7
    Last Post: February 23rd, 2010, 03:25 PM
  2. Dsp2
    By Drywall1 in forum General (Diesel)
    Last Post: March 3rd, 2006, 07:39 PM
