ok i just go my roadrunner pcm from another member. i put the license info in the license part. i can communicate with the rr but when i try to connect with the scan only via the obd2 port it says pcm not detected but at the bottom of the scanner it says connected. where it says pcm not connected is int he black screen part in the console section. i put connect and on that part while trying to connect it says pcm not detefted, ecm not detected. wtf lol any help thanks
using windows 7.
