Results 1 to 5 of 5
Thread: any reason why my flash wont work on car after i close the tuning file
    Dec 2009
    Exclamation any reason why my flash wont work on car after i close the tuning file
    ok here it goes.
    when i reflash my pcm with an 02 os with the fuel calibrations for a 98. it works initially. i reflash it os and calibrations. i then turn on the ignition and the fuel gauge works perfect and all i hear the fuel pump prim for 2 or 3 secs normal time. then i go and close the efi tuner then i connect to the rr, then i dl the os and calibrations to the tuner. i then try to turn key and the puel pump primes for less the a sec and the fuel gauge is full wtf. i notice this happens after i reflash and i close the tune.
    cause when reflash it initally i try and turn the key and everything is back to normal. then i go again and close the tune and save it under another name and i try to turn the ignitioin on again and again it does the same shit, the fuel gauge is up all the way and pujmp only primes for less then a sec wtf.
    would a low battery cause this? if so then why after i flash it via the usb and try to turn the ignition it works. this seems to work after the reflash, but when i close the file it does teh same shit. wtf help
    Oct 2004
    Try and disable (for a test) the VATS security option. I have seen it before where the engine will not crank (or run for a really short time) with VATS enabled.
    Andrew
    EFILive Crew
    Dec 2009
    ok ill try
    Dec 2009
    i disalbed the theft in emulation mode and turned it on again. problem was solved weird.
    Weird.... I made the mistake of turning off the emulator when driving... BAD IDEA.... Was wondering if somehow when you closed the file the emulator turned off.
    Quote Originally Posted by z28ls1818 View Post
  1. DSP5 wont take flash? Fuel vs Speed does not work?
    By Mitco39 in forum General (Diesel)
    Last Post: August 13th, 2009, 10:12 AM
  2. ac wont work at idle
    By hot-dog in forum General (Petrol, Gas, Ethanol)
    Last Post: July 23rd, 2009, 04:07 AM
  3. FTClean Wont work
    By Kiwi Ed in forum Tips and tricks
    Last Post: July 28th, 2007, 10:02 PM
  4. efi live wont work with lly?
    By titanspanker01 in forum Duramax LLY
    Last Post: February 27th, 2006, 01:23 PM
  5. Default Customer Details Page wont close
    Last Post: January 10th, 2005, 08:49 AM
