Results 1 to 10 of 13
Thread: HOW TO....enable GM.ENGOILP
    Oct 2007
    Default HOW TO....enable GM.ENGOILP
    how do i ennable this PID... its the engine oil pressure PID located in the conditions section... This is X'ed out for me. I guess its not supported unless i enable someother PID?
    http://forum.efilive.com/showthread....ght=GM.engoilp
    I just found this link ^^^^, how do i make a custom PID to enable this?
    car is a 2001 z06 w/ cos5 os # 02020005
    thanks...
    01 Z06, 4L60E CONVERSION, L92/L76 TOP END, 72# LS3 INJECTORS (THANKS FIC), DRY NITROUS, COS5
    WHYTRYZ06, also try GM.EOP.
    Remember to validate pids.
    Oct 2007
    Joe i cant find that pid, where is it?
    Andy,
    In scantool do this:
    - go File->Select Controller, and select GenIII LS1 99-08 PCM (should already have it),
    - go File->Enter VIN, and enter your VIN and OS (should already have it),
    - connect to vehicle,
    - go Info->Validate PIDs,
    - go to PIDs F8 tab, click on Caption column heading to sort alphabetically on that column,
    - set System to (All),
    - look down the Caption column to see if it's there.
    I asked Tech Support for more guidance on this.
    Oct 2007
    ok, ill try that.... ill call u as soon as i do ( r u available today?) and let u know what i find...
    thanks...
    Oct 2007
    joe, i dont think GM.EOP is on this update and build...I have build 88
    Oct 2007
    joe, i validated the PID's and it didnt work, do we need to make a custom PID based on what is given to us, I.E GM.EOPS,,,?
    Do any GM.xxxxx PIDs show up as valid?
    If not, there may be a non-standard VIN in that controller. Make sure the VIN starts with 1G, 2G, 3G, 4G, 5G, 6G or 6H otherwise none of the GM.xxxxx PIDs will show up as valid.
    If the VIN is ok, then the GM.EOP PID should be valid for your vehicle. It will only return the oil pressure as a voltage (from 0V to 5V) not as psi.
    Oct 2007
    ok, ill check now gimmie a min
    ok just checked, all that is valid is
    GM.EOL ( ENGINE OIL LIFE)
    GM.EOPS (ENGINE OIL PRESSURE SENSOR VOLTAGE) <<<< do i select this one?
    thats it, so what do i select....
    Blacky, when i log my oil pressure ima need it to show up in the scan tool as PSI...ok?
    so what to do?
    Andy,
    Select GM.EOPS...
    I'll send you an edited calc_pids.txt file.
  1. custom pid for GM.ENGOILP ...inside... sticky info
    Last Post: December 15th, 2009, 05:57 PM
  2. egr enable
    By kostelacd69 in forum General (Petrol, Gas, Ethanol)
    Last Post: April 6th, 2009, 07:01 PM
  3. HELP!!! AFM won't enable....
    By GAMEOVER in forum Gen IV V8 Specific
    Last Post: January 18th, 2009, 10:50 AM
  4. How Do I Enable IAT with MAF Disabled?
    Last Post: May 14th, 2006, 07:34 AM
  5. What rpm to enable LTFT?
    By Rich in forum General (Petrol, Gas, Ethanol)
    Last Post: September 19th, 2005, 06:56 PM
